Sail & Rigging - Broken boom |
Posts: 7 |
Broken boom I broke the boom on my Swan 44 during a gybe. It snapped very cleanly just in front of the kicker attachment, where there is a large inspection hole. The boom is oval-shaped: 203mm*116mm*5mm wall thickness and otherwise in good condition with no corrosion. Can this be repaired by sleeving and are suitable sleeving sections available?
Dear Simon
Posts: 164 |
Lars: can this also be done for the mast? We have the original Nautor mast on our boat, and I am a bit uncomfortable with the section just above deck level. When we bought the boat, the mast had eight wooden halyard cleats screwed into the material -- unfortunately, inox screws were used. |
Dear Martin |
Posts: 164 |
Thank you, Lars. I will discuss the idea with the rigger who will do the work. Mainly I am worried because of the screws in the cleats: when the one fell off, the corrosion area was slightly larger than the screw diameter on the inside of the mast but about the size of a 2-Euro-piece on the outside. Multiply that by eight cleats with two screws each, and you get a lot of missing material in the mast.
- Threads : 1715
- Members: 823
