| Sail & Rigging - Swan 38 Chain plate inspection instructions |
Posts: 34 |
Swan 38 Chain plate inspection instructions On The subject of chain plate failure as the most likely cause of rigging failures - are there any instructions or drawings to facilitate the inspection of chain plates on Swan 38's? Best, Patrick |
Dear Patrick |
Posts: 34 |
Many thanks Lars, Do you have any technical drawings for a s 38's chainplates? Regards, Patrick |
Dear Patrick |
Posts: 34 |
Thanks again Lars - I will get some Spotcheck
Posts: 30 |
If Chainplates pass through the deck (as opposed to being bolted onto the outside of the hull), the part of the plate that is most susceptible to corrosion is the area completely hidden by the caulking where is passes through the deck. It is here that the salt water will collect and the corrosion begins. To inspect this area the plates need to be unbolted, removed and cleaned/polished. (Do not kid yourself that by removing the caulking you can see.) I know it is/can be a lot of work but with some of these yachts getting to be 30 or 40 years old it is worth every minute. I lost one chainplate which broke at the top bolt. It was this bolt to which the ground wire was attached and the dissimilar metals caused the problem, (with the aid of a leaking chainplate). David 43/12 |
Posts: 34 |
Good tip and thanks - will look at the chain plates with interest. Someone told me that the old Nautor keel bolts are notoriously week - is this fact or a wind up (he was Scottish!) |
Dear David and Patrick |
Dear Members |
