| S&S Swan General - Chainplates bearers sheared |
Posts: 36 |
Chainplates bearers sheared ![]() Crack under pilot berth |
The chainplate loads are taken by GRP reinforcements on the plywood partial bulkhead. The reinforcements continue out on the topside, and it is likely that the laminate suffered damage if the bulkhead can move.
Posts: 36 |
The chainplate loads are taken by GRP reinforcements on the plywood partial bulkhead. The reinforcements continue out on the topside, and it is likely that the laminate suffered damage if the bulkhead can move. A detailed inspection of the area, and particularly the transition between bulkhead and topside is needed. Does the crack close if shroud tension is released? Kind regards Lars Hallo Lars
Posts: 36 |
This was just an intial look. The joinery is to be stripped out to get.a beter look at the damage |
Posts: 36 |
This was just an intial look. The joinery is to be stripped out to get.a beter look at the damage All is now stripped out. The plywood bulkheads have sheared on both sides level with the post at the base of the pilot berth. The surveyor believes this is simply the weakest point in the bulkhead where a corner cutwas made when built and that it has simply failed the test of time albeit after 30 years.. The starboard bulkhead went first and the port one seems very recent. The laminate appears to be intact. The proposed solution as checked by a naval architect is to glass in the cracks and spread the load with swathes of glassfibre in different directions before reinserting a much extended stainless steel chainplate base going down past the area where the crack occurred. I have the design drawings if anyone is interested. (A word of warning - it is not cheap but, as the surveyor said, that is the price of owning a beautiful old Swan!). |
Posts: 252 |
All is now stripped out. The plywood bulkheads have sheared on both sides level with the post at the base of the pilot berth. The surveyor believes this is simply the weakest point in the bulkhead where a corner cutwas made when built and that it has simply failed the test of time albeit after 30 years.. The starboard bulkhead went first and the port one seems very recent. The laminate appears to be intact. The proposed solution as checked by a naval architect is to glass in the cracks and spread the load with swathes of glassfibre in different directions before reinserting a much extended stainless steel chainplate base going down past the area where the crack occurred. I have the design drawings if anyone is interested. (A word of warning - it is not cheap but, as the surveyor said, that is the price of owning a beautiful old Swan!). I'm not sure how freely you're willing to share the drawings. I have no need of the repair, but I am interested in seeing how the revised design was brought forward from an engineering point of view and just to learn a little. Plus, my boat did have her chainplate knees stiffened, so the subject is of general interest from that point of view, too. |
Posts: 36 |
Will get the drawing on the forum and send it to you in the next week! |
Posts: 36 |
Attached the chainplate strengthening drawing Chainplate strengthening |
Posts: 155 |
I can not see
Posts: 36 |
Can i send it to you directly to upload?
Posts: 36 |
Posts: 155 |
Thank you, it is possibile that I am not managing to download from my IPad. |
