| Sail & Rigging - Baby stay Swan 38 |
Posts: 25 |
Baby stay Swan 38 |
Dear Enzo
Posts: 30 |
Hi Enzo , I am not familiar with the 38 but sometimes a baby stay can make a fairly acute angle with the mast, thus loads up a lot. I don't know what your pole topping lift is made of but if it is polyester double braid it will not work satisfactorily. If it is a top grade dyneema ( i.e.SK75 ) it will stretch approximately the same, diameter for diameter, as 1X19 wire, BUT since it is twice the length this will result in half the effectiveness. How will you tension this makeshift stay? Will you take it off and put it on often (if not creep must be considered)? As Lars mentioned, is your hardware up to the loads generated? I have heard that a synthetic stay will be slack in the mornings but tighten up during the day (aluminium and plastic behave differently in temperature changes.) In my humble opinion, if you need a baby stay it should be wire (or the same material as the rest of your rigging) Happy sailing. David 43/12 |
