| S&S Swan Maintenance - Ventilation of Gas bottle container |
Posts: 234 |
Dear John
Posts: 234 |
Dear Lars, thanks I have just read the thread. 2 winters ago I renewed my pipework at the bottom of the tank. The old pipe frequently got water up it and was partly blocked with weed etc. I had a large gas escape whilst sailing along the South Coast to Cornwall earlier that year. Fortunately I had fitted a gas alarm. I called up the Coast Guard to advise them of my situation, switched off everything electrical and sailed on to the nearest port which was Brixham. I was prevented from entering the port as I was considered a danger to shipping. After ventilating and pumping, all was well. Having replaced the damaged joint behind the cooker I was told that my system also needed to be updated so that the pressure can equalize in the aluminium tank. So later I checked out and replaced the discharge to sea. But from what I see this is not enough and I now need to allow further escape of lighter gas but not into the bilge. Given our set up this is near impossible. |
Dear John
Posts: 234 |
Lars, my installation is the same as other 411s. The regulator is attached to the gas bottle and by a rubber hose to the through cylinder fitting. The only modification I made was on the underside of the cylinder lid a stuck a rubber gasket to try to seal off the cylinder. This I tighten down and form a hopefully air / gas tight seal. So if I had a gas escape then the gas could only exit by the bottom discharge and not seep out through the top of the cylinder and into the bilges. But now I am not sure if this is a correct course of action. |
John
John, |
Posts: 79 |
John,
Posts: 148 |
I agree with Daniel - a solenoid switch to the regulator activated from the galley with a clear on/off light is a must. As long as the switch is used it will prevent any leakage in the pipework between the cylinder and oven. I have 2 sensors on the alarm - one under the oven and one low down in the lazarette. First boat rule - "switch off the gas when the kettle has boiled!"
Dear Adrian
Posts: 234 |
Guys. Thanks.
Posts: 79 |
Lars,
Posts: 203 |
Ouch!
Dear Philippe
Exactly, same use of the small manometer. It is a useless device for judging the remaining gas because the pressure of LPG does not fall until all liquid is evaporated inside the gas bottle and it is obviously too late; although not everybody knows it, its only use is for finding leaks. Close the gas bottle and check how long it takes for the pressure inside the circuit to fall. A fast fall - I would add also any not-extremely-slow fall - is a sign of trouble which requires further prompt investigation. |
Posts: 234 |
Philippe, we seemed to have had the same approach. The simpler the system, the fewer joints the likely fewer problems. Also easier to fix.
Posts: 177 |
Hi everybody, I can only recommend the system mentioned by Daniel and Rob. In particular, it makes the shut-off of the gas bottle so easy that crew does it regularly. My impression is that the more "effort" a measure takes, the less often it will be taken (see the discussion about preventing accidental gybes) so I am quite familiar with boats that have the gas bottles open all summer or at least all day, with just a shut-off over night.
Hoping for no leaks at all, gas or not,
John, |
