| S&S Swan Maintenance - Check your bolts! Swan 40 |
Posts: 2 |
Check your bolts! Swan 40 ![]() ![]() ![]() |
Posts: 155 |
Dear John, |
Posts: 2 |
Thanks for that, Matteo
Dear John and Matteo
Posts: 243 |
Dear Lars et al.,
Posts: 252 |
Certainly the professor is right that 316 is better in pitting and also crevice corrosion than 304 - it is a big part of why 316 came along. Having said that, even 316 over time can suffer this fate - and the worst of that is this corrosion and type of failure is very insidious, sometimes not showing so much from a visual inspection. If you are to replace the bolts, consider super austenitic or duplex stainless steels which are almost immune to this type of failure - such as Avesta 254 SMo, or Ferralium - it might be very expensive to find or even get bolts made, but compared to a rig failure, not much at all, and the peace of mind well worth even a couple of thousand dollars. I will be checking mine, you can bet. |
Posts: 243 |
Hi Guys,
Posts: 88 |
You had me really concerned, but it appears Cygnus is OK. Attached are two pictures of the bolt from the port side chain-plate, just inboard of the welded tang. There are no markings on the head of the bolt. It is non magnetic. ![]() ![]() |
