| S&S Swan General - Swan 37 change from tiller to wheel steering |
Posts: 10 |
Dear tleach
Posts: 10 |
Dear tleach Sprocket and chain recommended. The standard wheel diameter was 30" with 1.24 turns HO to HO and +- 35 degrees max rudder angle. The equivalent tiller length with this geometry is 8.1 ft, considerably longer than the present one. Suggest you check what Edson and Lewmar can offer towards achieving this geometry. If required I can assist with choosing the components. Rack and pinion not recommended, at high loads there is the risk of the pinion jumping the rack, and with the time wear will make the steering sloppy. Kind regards Lars Thank you Professor Lars!
