S&S Swan Maintenance - Grey water tank (411)
27 July 2015 - 14:44
Hi All
Our grey water holding area (under the head floor) has cracked, and the water now seeps into the bilge. We are likely to have to reglass a large area of the sump. Anyone else had to do this? Also, how best to approach it, as the current floor is moulded, with only a small(ish) inspection panel under the duckboards where the drain goes in.
Any and all suggestions welcome!
Tom (411/025 - Sophie B)
28 July 2015 - 19:16
Dear Tom
There are at least two alternatives:
1- Cut out a big enough panel in the shower pan floor to enable repair of the sump tank. The panel then should be re-attached along the edges, preferably by bolting.
2- Cut a hole below the head door and into the sump tank. Lead a hose from the present shower pan drain fitting out through the holes to a sump tank box with pump located under the floorboards. The available height may be a restriction.
See for example http://www.whalepumps.com/marine/product.aspx?Category_ID=10020&Product_ID=10046&FriendlyID=Whale-Shower-Sump-System
28 July 2015 - 22:37
Lars,
Thank you. #1 had occurred to me as the 'obvious, but messy, solution'. #2, not so much. I will spend later this week with a measuring tape to see whether this might work. But I think #1 is the likely candidate.
