| S&S Swan Maintenance - Genoa car renovation |
Posts: 166 |
Genoa car renovation I am also looking for replacement plastic sliders between car and rail. Given the age of the cars I assume they would need to be machined? I will at any rate also approach Lewmar. Christian 028/411 IF ![]() |
Posts: 203 |
Hi Christian.
Posts: 166 |
Thank you Philippe! Maybe this is a difference between the 41 and the 411. I have 32mm tracks, the cars are from Lewmar (the name is on the car but not visible on the photo above). I now looked at photos of 411s on classicswan.com; it looks like there are multiple kinds of cars in use. I have also contacted Lewmar. Christian |
Hi Chris, |
Hi Chris, |
Posts: 33 |
I replacd the original ones with new Newmar and had to slidely adjust the plastic bearings with a hand-tool, which was only a few hours work |
Posts: 166 |
Regarding the sliders, I was wondering if 3D printing is a way to get them fabricated. They should be fairly simple to draw in a CAD tool. I will add progress reports to this thread. Christian 028/411 IF |
Great job Chris, my compliments! Now I am sure that many of us will follow your path, myself included. |
Posts: 155 |
Dear Chris, now that you have removed the knob, you might think at something more functional for tuning your jib.. ![]() ![]() |
Posts: 155 |
oops, crazy language originated from the smartphone.... |
Matteo, those wonderful old Lewmar cars already allow what you are suggesting. Putting the knob in the proper position the pin remains up freeing the car. |
Posts: 155 |
Dear Daniele, |
Sorry for the misunderstanding, I was indeed explaining how the cars of our 411 are made, not yours. |
Posts: 166 |
I got the parts back from chroming and they look spectacular. I now need to find a solution for the plastic sliders and the bumper rubber. I also wonder if there has been some kind of plastic piece between the axis and the block, to make the block sit tight. On low winds, the up and down of the block creates quite a bit of noise. Would anybody know? I am having the axis that holds the role rebuilt since I needed to drill it out. Christian 411/028 IF |
Dear Christian,
Posts: 48 |
Hi Matteo,
Posts: 166 |
The genoa cars are now finished, back on board and have already seen a few days of sailing. I used a handcut piece of UV-resistant rubber between the block and the car, so that the block stands up straight again. I also found sliders - via svb.de I purchased Pfeiffer Marine Sliders Number 74 4100260 02 124mm. Pfeiffer Marine has an online catalogue where you can easily find them. They are too short for the Lewmar sliders, but otherwise they fit perfectly. With four sliders, cutting off the ends, you can equip one Lewmar car. Press fit using pincers, no need for glue. The cars now look like back in the Seventies, they glide easily and they are silent, because there is no more metal on metal banging in low winds. Christian, IF 411/028 |
The genoa cars are now finished, back on board and have already seen a few days of sailing. I used a handcut piece of UV-resistant rubber between the block and the car, so that the block stands up straight again. I also found sliders - via svb.de I purchased Pfeiffer Marine Sliders Number 74 4100260 02 124mm. Pfeiffer Marine has an online catalogue where you can easily find them. They are too short for the Lewmar sliders, but otherwise they fit perfectly. With four sliders, cutting off the ends, you can equip one Lewmar car. Press fit using pincers, no need for glue. The cars now look like back in the Seventies, they glide easily and they are silent, because there is no more metal on metal banging in low winds. Christian, IF 411/028 Great finding Chris, and thank you for the information! Daniele, 411/004 Luna Menguante |
Posts: 396 |
Dear U.S. Members, I'm trying to locate the best place to send my parts for re-chroming. The machine shop I use suggested: http://www.paulschrome.com/ Any other suggestions? Chris Mabel's Casse Tete 43/003 |
Posts: 88 |
Hi Chris I've had very good results from http://classiccomponents.com/ Have used them 3 or 4 times so far. They do polishing too. Good luck! Tonyh |
Posts: 396 |
Thanks, Tony, I'll try them!
