| S&S Swan General - Lighting Protection |
Posts: 234 |
Posts: 88 |
A friend of mine got hit by lightning one day out of a Westcoast port. He had a 28 ft boat. It destroyed all his electronics, except the handheld VHF he had put into the oven. I guess the stove was grounded. He returned to port for repairs. My 040/012 has copper cables from the chainplates to the keel bolts. I have been in lightning storms and it is spectacular. The lightning hit the wave tops around me but never the boat. I read somewhere that the purpose of a lightning rod is, to discharge the electric static charge to ground, without the visible flash. |
I have just been on a tour of Discovery Yachts factory in the UK and the subject of conducting a lightning strike came up. Discovery say that aluminium is a better conductor than copper, so they wire the mast directly to the keel bolts in two places. Is this an improvement on the Swan approach of fitting a faraday cage? John B Swan411 010 The matter of lightning on sailboats is highly controversial but, in particular, stating that the aluminum is a better conductor than copper does not make sense. The specific resistance of aluminum - the quantity commonly used to define electrical characteristics - is nearly the double than the one of copper and only for applications where weight is of high concern, Al may be a better choice due to its low specific weight. Notice: weight (or, better, mass), not volume which, indeed, must increase to obtain the same characteristics! |
Posts: 203 |
Hello John, Peter, Daniel,
Hi Philippe, |
Posts: 234 |
Daniel. On our Swans the path would be for the energy to pass down the stainless steel shrouds to the copper cable which is attached to the chain plates and then onwards to the keel.
Dear John and Daniele
John, |
