S&S Swan Maintenance - Seacocks
04 February 2018 - 18:19
Seacocks
I am sure you all have been seeing this question many times, but unfortunately I can not search for the topic.
Are the blake bronze seacocks the recommended ones for replacing the old onces of our Swan 48 S&S?
Thanks for your reply!
Ulli
THEMIS
04 February 2018 - 18:24
Dear Ulli,
eveni if quite expensive, and nowdays available in two sizes only, I think their simplicity and the fact they are very long lasting make them the best product (at least this is my opinion).
When I replaced them onboard Only You (after 35 years) I installed Blakes again
12 February 2018 - 00:53
I agree with Matteo.
I replaced my Blake seacock on Swan 43 "Hiro Maru" in 2000 and it is still fine.  They are a simple design that invites routine maintenance and the materials used are first rate.
Hiro
07 March 2018 - 16:17
Hello dear S&S Swan fans!
I fully agree with what is being written above, but also recommend using Blake's special grease. It does limit corrosion and blockage as far as I can experience, which is not the case of all marine greases.
Kind regards.
Philippe 41/022
