S&S Swan Maintenance - Steamhead on S. 47
02 October 2019 - 17:18
Steamhead on S. 47
while re-decking 47/069 Vanessa I took the opportunity to dismantle even the steamhead, would you suggest any specific reinforcement on this very sensible fitting?
Thanks so much in advance!
03 October 2019 - 06:37
Dear Matteo
Two comments
- The headstay lug plate looks thin, if thinner than the gap in the toggle lower end, the recommendation is to increase the lug thickness to the maximum that fits.
- There is an extension piece at the headstay lower end for raising the furler drum. Should be checked that there is proper toggling action at its lower end. If you could send a close-up photo of this extension I can comment.
It is assumed you have removed the second forestay.
03 October 2019 - 13:35
Thanks a lot dear Lars!
Back to Vanessa in 10 days, and I will take macro pics !
15 October 2019 - 19:28
I thnink the welded spot is the weak one, I have been suggested to weld a 4 mm. thick plate on the outside side. What do you think?
Thanks in advance!
16 October 2019 - 11:12
Dear Matteo
The corner shown by the arrow is a highly stressed area.
It is suggested an additional small triangular plate - say 20 mm edges -  is welded in there between the lower edge of the deck edge plate, and the stemhead plate outer edge, with a nice radius on the aft edge. Thickness as deck edge plate.
Both sides!
16 October 2019 - 12:59
Thanks so much dear Lars,
will do !
24 October 2019 - 07:41
Hello Matteo
It could be oif some help to have a close look at what I did with the steamhead of my beloved Farouche: reinforcement under the deck- prolounged front part on the bow and reconfiguration of the surface on deck with a larger area.
Please see pics.
//Philippe
Reinforcement under the deck
Enlarged surface on deck
enlarged front piece on the bow
24 October 2019 - 13:05
Hi Matteo,
Having removed the stemhead fitting on Sarabande, I took the opportunity to add another roller on the port side. This was in part to allow me to fit a sprit, but also to take heavy mooring lines which were too big for the cleats, and to save the hassle of removing the anchor. Since then, I have switched from CQR anchor to Rocna, which does occasionally "jump out" if raised too quickly, and I now wonder if further modifications are necessary to the fitting. I dont expect any of the above is of interest to you because they are not authentic etc, but sometimes sharing practical exoperience can be helpful.
Tidy bit of reinforcement Phillipe!
Very best
Rob
Sarabande 47/029
24 October 2019 - 16:22
Dear Philippe and Rob,
thanks a lot! Actually under the deck I found the very same strenghtening (done by the previous owner).
I am very happy with the Ultra anchor, which fits on the original roller as it had been built accordingly, so, no need to modify it (and as Rob suggets, I don't like sprits).
