| S&S Swan Maintenance - Dropping the headliner on a 38 |
Posts: 8 |
Dropping the headliner on a 38 I need to access the coachroof from inside to replace broken deck cleats. I know the teak strips have to come out first but, are they held in place by anything or just tension? ![]() |
Hi DubaiSwan, |
Posts: 8 |
Thanks Matteo! Saves a bit of work!
Chris |
Dear Matteo A correction - the teak strips on the old boats are not held up with Velcro. Instead the distance between the overhead panel edges is carefully matched to the width of the teak strip, so when the strip is pushed in it stays there. An invisible tribute to the detailed work of the carpenters.
For removing the strips the method of attachment does not make a difference - start at one end, and be careful not the break them
Dear Lars, thanks, you are fabulous! 😁 matteo (47/069 Vanessa) |
