S&S Swan General - Hull // signs of repaired damages
29 September 2020 - 10:01
please see this thread for my introduction:
https://www.classicswan.org/forum/post_thread.php?thread=2439
Heres another issue:
The cladding of the gas tank in the aft of the cabin is missing, theres a reinforcement under the cockpit and some repairs on the sides of the companionway.
They somehow do not make sense to me, cannt figure out what the original event causing this damage could have been.
I suppose the caldding was taken away as the new bigger gastank was installed.
But does the reinforcement under the cockpit serve as a replacement for the structural work the cladding was doing?
Maybe this somehow connects to the keel issue?
Any suggestions?
Thanks in advance, Timo
29 September 2020 - 10:02
29 September 2020 - 10:03
And some general pics of hull. Cheers Timo
29 September 2020 - 10:04
29 September 2020 - 10:05
29 September 2020 - 10:06
29 September 2020 - 10:07
30 September 2020 - 18:51
Timo
A few comments about the photos
- The fuel tank was originally laminated, but has been replaced with a steel tank.
- Cockpit seat drains have been enlarged to same size as the cockpit well drains.
- An unpainted wooden support beam has been added across the entrance, there are screws in it, where attached?
Photo 2
- Not clear where taken
Photo 3
- Near the entrance?
Photo 4
- SB pilot berth. Some damage at the deck edge
Photo 6
- This is likely to be the mast step
Photo 7
- Where taken?
Photo 8
- Appears there is damage at the edge of the hole. where taken?
Photo 9
- The seacock handle has been deformed by brute force when the cock has jammed. Has the handle been extended?
Photo 10
Photo 11
- Result of a water leak
Photo 12
Not clear what this is
Photo 13, 14 15
Not clear what they show
Photo 17
Rack and pinion wheel steering added later. Rod disliked these systems.
