| S&S Swan General - Bow thrust on a 48 |
Posts: 177 |
Bow thrust on a 48 Dear all, after another narrow escape in a narrow marina we have (almost finally) decided to install a bow thrust on our Swan 48. My questions to those of you who sail a 48 (or 47) with a bow thrust: I believe we could gain a lot out of the experience we cannot yet have, so I am counting on those of you with similar boats ... Wishing you fair winds and wide marinas, |
Dear Martin It is assumed you are looking at tunnel thrusters. Some 100 kg of thrust suggested
Here some general geometric advice for a proper installation.
The thruster should be as far forward as possible, but sailing yachts have shallow fore bodies, and this restricts the position.
Tunnel diameter 8...10 inches, local hull draught 2...2½ ft, tunnel top submerged one diameter in order not to suck air, and one diameter of hull depth below the tunnel, as well as a tunnel length of two diameters to avoid undesired cross-flow
The tunnel ends should be rounded where they meet the hull with a radius of 10 % tunnel diameter, Making elliptical recesses aft of the tunnel so the ends are parallell with the centerline reduces the added resistance
Posts: 177 |
Dear Lars, thank you very much for the detailed information! I haven't talked to the yard doing the installation yet, at least not about details - as of now, I am still open about a retractable thruster provided we can afford it. Do the two types - retractable vs tunnel - compare in strength? Best regards, |
Dear Martin You ask about the strength, assume you mean the thrust?
A tunnel thruster often does not achieve the expected thrust, because all the geometric requirements can not be met, and each deviation reduces the output to some extent.
Retractable thrusters are more predictable in this respect.
Also the retractable thruster has a piece of the hull below the tunnel - the panel covering the hull opening when closed.
A too short tunnel with too little hull depth below it will suffer from undesired cross flow, which reduces thrust.
Posts: 23 |
Hi Martin After a few seasons in the Med getting the bow blown off while trying to dodge anchor lines while mooring up I've nearly decided to fit a bow thruster to Snow Wolf, Swan 48. I've noticed the wind always picks up in the Med just when I'm trying to berth stern to! We will be going for a vertical retracting thruster just forward of the anchor locker bulkhead. I've been investigating Lewmar or Maxpower.
A Swan 48 that was previously called Jocobite had a bow thruster finished when she retired from racing. Not sure what Jacobite is now called but the owners may be members of ClassicSwan. |
Dear Martin and Snow Wolf, she is hull 024 Sleeper |
Posts: 177 |
If Sleeper X really has a bowthrust, that should put to silence every argument that "these things make you slow". I've seen her racing, and that boat is certainly anything but slow (even conceding that Jacobite was, if I recall correctly, a bit lighter on the scales than the other 48s). I know that Montana has a bowthrust as well - I'd be interested in its position and the crew's experience with it. I'm considering a retractable thruster as well, and the area of the chainlocker bulkhead seems to be a natural position. I just need to see if we can then still store 75 meters of anchor chain as well ... Best wishes, |
Dear Martin Assuming that your anchor chain is 12 mm, 75 m would occupy a volume of approx 130 liter.
Posts: 9 |
Dear Martin! It's some time ago but I know that Dantes removed their tunnel thrust from their 48 S&S because it took too much space in the stern. May be they still have it ir willing to sell it!? Ulli THEMIS Swan 48 #16 |
