| Sail & Rigging - Swan 36 lee helm |
Posts: 8 |
Swan 36 lee helm Our Swan 36 gives lee helm. This can be solved by changing the lateral point. Anyone has the same experience with this ship and solved it with adjusting the length of the forestay ? To which rake ? thanks Robert |
Dear Robert According to S&S the mast should rake aft 6" at the top. Assuuming you are close to this setting, then adjust the sails so there is some weather helm
Posts: 8 |
thanks Lars 6 degrees seems to be a lot...... best regards |
Dear Robert Pls note that the sign (") means inches. This is measured at the top of the mast. Kind regards Lars |
Posts: 243 |
Hi Lars, Sorry to jump in but on the same issue.. I had a new forestay made and think the new one is too long. But given Lar´s comment maybe not. How much rake should the 40s have? We are prepring for a long trip and do not want to weaken the mast or fittings... Fair winds
Mike from Stormsvale
Mike The S40 sail plan mentions the same 6" as for the S36. This is a little inconsequesnt, as the rake in inches should increase with mast length. 1 degree is suggested. Kind regards Lars |
Posts: 8 |
check thanks 6 inch to the deck or mast step ? Looks I have already double now... If the boat is on its original waterline and not bow up .... How to check that ? Its nice to work on these details with a boat..)
Dear Robert Measured to the deck. Would there be another 36 around to compare with? Looking at phtos meáy also be helpful Kind regards Lars Lars |
