S&S Swan Maintenance - 57-043 Kairos - Refit |
Posts: 102 |
As mentioned in previous posts we decided to keep Kairos, our Swan 57, on the dry in 2021 due to the ever-changing travel restrictions making it very difficult to plan the season.
Now, what do you do when you can’t sail and therefore have time to think (too much)? You come up with some non-rational, crazy ideas … in our case we asked our yard to provide a very rough indication for a new teak deck ‘just for information’ in February 2021… it arrived very much as a fully detailed quote.
When we bought Kairos in 2017 we knew we had some leakage issues with our aging teak deck leading to water damage below deck. These were successfully addressed and we would have probably been ok for another few years but on the other hand it appeared a too good opportunity to miss since the season was already ‘over’ anyway. And after all, the earlier you do them the longer you can enjoy them, right?
The problem - when the deck is new, the hull will look even more tired than before …the same with the cockpit, coamings and coach house … what about the grinder pedestals? And the steering column? … and ‘while we are at it’ – what about …?
One item led to another and to make the most of the ‘downtime’ we ended up commissioning our yard with some larger work items that, while not immediately urgent yet, were on our to-do list for the next few years anyway.
This is a summary of what happened, which I hope you will find interesting.
We eventually managed to stop expanding our wish-list in the end and tasked the yard with the following key works:
- new teak deck, all planks laid and glued individually, 12 mm thick, 42 mm wide
- painting of hull ('Flag Blue'), water line ('Snow White') and deck areas, coach house, cockpit etc. ('Off White') with Alexseal two-component paint
- sandblasting, powder coating and painting of grinder pedestals & steering column
- re-instatement of the after companionway that had been replaced with a Lewmar hatch by a previous owner
While the works are not quite completed yet I finally found the time to select some (too many, probably - sorry!) photos and share the approach with the Forum, following the good example set by Yves/Algol 5! 2021 seems to have been the year to refurbish your 57 😊
Hopefully the pictures and subtitles are sufficiently detailed but please don't hesitate to ask any questions.
I'll try to provide updates on the further progress in a more timely fashion (I hope).
Kairos - 57/043
The existing deck had been replaced around 2000, we think Would have lasted another few years ![]() After companionway having been closed off with a Lewmar hatch |
Posts: 102 |
We had some known issues with the current teak deck, which we believe was replaced around 2022 Namely, it was leaking through into the compartment walls amidship This was due to a broken fish that had become lose; alsop, the chalking was badly worn and detached at several places Water damage below t Found the culprit and replaced broken fish planks Also re-chalked worn areas across the whole deck in 2018 |
Posts: 102 |
We had the chalking replaced where it was bad, and also had some work done around the puttings in the following years 2018/19 At that time the yard already had some suspisions about how well the current deck was still attached to the substrate below ... Plan was to keep patching up until a new deck would be required one day ... Chalking was very lose in places ![]() Also had some slight leakage around the puttings that was addressed Slightly sanded and re-chalked deck after the patch-ups - looked good |
Posts: 102 |
So in March 2021 we went ahead with a new teak deck. Our yard went to select the teak right away; turned out to be very good timing as virtually a month later Burma teak was on the embargo list and stocks cannot be replenished... ![]() Start of the removal of the deck fittings ![]() Cockpit floor removed ![]() Grinder pedastal |
Posts: 102 |
So off went the old deck. Turned out that it was laid as prefabricated sections that were glued on a base layer, which was then glued onto the subtrate of the deck. Not a problem if it's properly down with adequate vacuum etc. but by the looks of it, it didn't work well for Kairos. There were plenty of areas where there was inadeuate adhesion and air pockets; any water ingress was able to travel almost freely betwee the base layer and the substrate deck ... ![]() As expected, the bonding of the old deck wasn't good ![]() Air pockets and inadequate adhesion everywhere ![]() Not a pretty sight but progress |
Posts: 102 |
After the removal of the old teak deck, the substrate was sanded extensively to remove the old adhesive. To ensure water-tightness and also to provide a good base for the new deck, the substrate deck was then laminated over ![]() Old deck rempoval almost complete ![]() Newly laminated deck base, after a lot of sanding ![]() Grinder pedastal and steering column on their way to blasting & powder coating |
Posts: 102 |
And finally - on with the new deck! ![]() New teak planks being prepared / glued together ![]() New planks ![]() New deck coming together |
Posts: 102 |
![]() Coming togehter nicely ![]() After ![]() Weighed down with lead the old fashioned way |
Posts: 102 |
![]() Almost there ![]() Let the chalking begin ... ![]() Cockpit teak planks were prepared in the workshop |
Posts: 102 |
Finally the chalking and sanding could commence and for the first time we were able to see the new deck 'fully' ![]() Newly chalked ![]() Sanded and new ![]() Looking very pretty |
Posts: 102 |
Most woodwork surounding the hatchses was also replaced and two new prisms purchased for the forward heads. ![]() Good result throughout ![]() New hatch-surrounds ![]() New prisms with surrounds |
Posts: 102 |
Once the deck was completed, the painting comenced. First the coach house, coamings and cockpit together with other deck components such as the boxes of the Dorade vents were primed ![]() Cockpit primed ![]() Coach house primed ![]() Deck components & steering column primed |
Posts: 102 |
Final painting was completed toghether with the reinstatement of the rear companionway. For the latter a new sliding hatch and boards were manufactured similar to the design of the main companionway. The rear companionway will not have a key but bolts from the inside only. ![]() Finished coachhouse and cockpit ![]() Coamings looking very shiny ... ![]() ... and so does our new after companionway |
Posts: 102 |
Next was the preparation and painting of the hull. ![]() Prepairing the hull for painting ![]() It always looks so much worse before it eventually looks better ![]() Very shiny! |
Posts: 102 |
Painting etc. is now complete and the deck fittings are being reinstalled. We have also refurbshed the Neco 692 autopilot with the kind support of Daniel Fua, which I will cover in a separate thread. Plan is for Kairos to be back in the water in early April with the first trip scheduled for after Easter. Fair winds! Stefan Kairos - 57-043 ![]() With name etc back on ![]() While the deck fittings are being installed ![]() Still some way to go but getting there |
Posts: 92 |
Superb work and superb result Stefan, thanks for sharing, it is important and a big help to share together our experiences ! Congrats ! Yves / Algol - 57 007 |
Posts: 102 |
Thank you Yves! Kairos is now back in the water, looking much tidier already! Mast and still some items from the punch list under deck but all on track for the first trip after Easter - fingers crossed! Fair winds Stefan Kairos - 57/043 ![]() ![]() |
Posts: 102 |
![]() Whole-length teak planks |
Posts: 102 |
Dear All, we have just completed our first short trip on Kairos after she's been on the dry for over 1.5 years ... sailed from Hamburg (GER) to Ebeltoft (DK) after Easter and thoroughly enjoyed it! Kairos looks lovely after the refit and except for a few (expected) 'toothing issues' after such a long time and some leakage around a hatch, which will be addressed soon, everything worked a treat. A few impressions below, can't wait to sail to Bodoe (N) later in the year! Fair winds and a good 2022 season, Stefan Kairos - 57/043 ![]() View forward from the cockpit ![]() Refurbished/painted floor boards below ![]() Moored in Ebeltoft near the Fregatten Jylland |
Posts: 92 |
Fairwinds Stefan ! Kairos looks great !!! Yves |
Posts: 928 |
Dear Stefan, |
- Threads : 1639
- Members: 791
- Online Members: 3
