S&S Swan General - Swan 38 Spinnaker pole channel drains
28 March 2022 - 20:13
Hello.  Both spinnaker pole channel drains have blocked.  Is there a preferred way to clear them?  I've tried with a piece of wire and high-pressure blast of water but neither has cleared the blockages.  (The drain hoses go though some quite tight corners.) Any advice most gratefully received.
John and Sue
 Serafina (38/039)
29 March 2022 - 07:56
Dear John and Sue,
you are correct, there is a tight corner at the end of the hose, did you try with a wire (the same one electricians work with when they have to follow a hidden hose underneath a wall should work very well) starting from the end, just above  water level? It should work.
Please keep us updated.
29 March 2022 - 11:46
Dear John and Sue,
If you can't clear the spinnaker pole channel drain hoses, they can be replaced. I did it on our Infant (38/014). To get access to the deck ends of the hoses I had to cut out part of the grp-cover inside the oilskin locker and above the fridge. The latter cut I had to cover by constructing a teak casing. The result is good.
Jyrki
