S&S Swan General - Bolt for sounding fuel tanks
04 June 2022 - 18:08
I am looking for a spare or two of the flange bolts that unscrew to sound the diesel tanks on a Swan 47 (104L). I have been told that they are M16 x 1.5. This appears to be a difficult part to source. I am in California (USA).
Any ideas?
05 June 2022 - 05:10
I haven't heard of a bolt of only 1.5 mm length, most are longer (16 mm is the diameter).But if I don't misunderstand, the solution might be easier: any M 16 will do for the sounding hole.
I assume you mean the center bolt in the inspection cover. There is a lot of space underneath; after all, the sounding stick should be able to pass. Make sure that it is actually an M16 that you need, and take a short one - the longer they are, the more turns are needed before and after sounding. I'll keep my fingers crossed that you will be able to find a metric bolt in the US; if not, we'll find a solution.
Martin
05 June 2022 - 10:49
M16 is 16x1.5mm… this is not the lengh but the screw dimension, not difficult to find in EU website…
Yves
06 June 2022 - 03:15
The flange bolt is 16 mm in diameter with a 1.5mm thread pitch. The length is about 20mm.
08 June 2022 - 19:30
When I lost mine, I asked my local fabricator to make one up which he did, but it was not a standard metric size, ( cant remember the actual thread size he used) but his best effort was a tight fitting bolt which does not leak. I think it must have been an old imperial thread. Of course I found the original when I came to remove the tank and find it beneath!
Rob
Sarabande 47/029
