S&S Swan Maintenance - Mast base 411
19 August 2022 - 07:21
Mast base 411
Hello dear mebers, I am restoring my mast base and need an advice.
I get a new Mast base and I want to galvanize it.
I am not sure, if galvanizing is the right thing. is that may be contra produktiv?
would be happy for any advice.
Stefan on World Traveler 411#02
19 August 2022 - 07:39
Dear Stefan,
well done.
Yes, galvanizing is the correct procedure.
Could you please send some more and detailed photos, before/after?
Thanks!
matteo ( 47/069 Vanessa)
19 August 2022 - 11:04
Thank you Matteo, ok, than it is no brainer any more!
For the shoe i made a mold and themn the model, so the metall worker is having a template of the Mast.
Since the Mast is corroded too i will do it like Christian on his 411 with a aluminium insert and fiberglassing for galvanic insulation.
New wiring i have to do too.
Is there some think to know taking the mast out???
because it is a two part one.
here some more pictures:
19 August 2022 - 16:16
Dear Stefan,
mast base/step (and mast, of course) are connected to the keel for corrected grounding, and must be.
19 August 2022 - 19:36
Ah, verry good you are reminding me, i would have forgot to make a wire from the mast since it will be isolated - thanks matteo!
