S&S Swan Maintenance - Stuffing around rudder post - Swan 47
07 July 2009 - 21:46
Hello Forum.
On our trip across the Atlantic, we developed a leak from around the rudder post. Popular opinion believes the stuffing needs to be replaced. I am looking for input on the following:
1. What is the technique to replace the stuffing?
2. Does it require a haul out?
3. Where does one find the tool to loosen the silver casing that contains the stuffing (see pic)?
4. What does the tool look like? (a pic would be great)
I look forward to your responses.
Cheers,
Milo
s/y The Last of the Normal People
47(048)
09 July 2009 - 08:46
Dear Milo
Pls look at previous contributions within this thread.
Your questions:
1. Described previously
2. Haul out not needed
3. A tool was originally delivered with the yacht
4. See earlier contributions
The size of your seal is 3/16 inch
09 July 2009 - 10:11
Dear Milo,
I had the same problem on my 48' which I solved quite easily replacing the stuffing material inside the gland.
To undo the big "nut" you have to buy a special tool which is a key sold in different measures ( mine is n.3) which one loose arm on one side with a pin at the end. Brand is "USAG" and it was quite expensive , about 100,00 euros.
It would be better to buy two : one to keep the lower bolt in place and the other to open/close the upper nut but in my 48' there is not enough room to operate the lower one , therefore I used a big player to stop the lower part from rotating.
Once loose , you have to take off from the inside all the stuffing . In my boat I found 6 layers of stuffing in the shape of 6 pre-cut circles .
To take of all the stuffing inside I used a very small flat end screw + a thin knife blade to push it from the outside space between the gland and the shaft. Not an easy job to do but I was able to do it in less of one hour. As suggested from Lars DO NOT USE graphite stuffing material but only Teflon one. It's more expensive but you won't have corrosion problems.
Then you have to cut 5 to 6 circles corresponding to the diameter of the shaft and squeeze them inside. Lars suggested me to use a 8 mm size but it was to big to push inside , therefore I am now using a 6 mm one.The circles must not be aligned .
Once in place , close the gland tightening first the upper nut until you will notice that the wheel strats hardening and then tighten the lower one.
Go out sailing ( motor -saling) and check for any leaks. recheck it after 50 engine hours
I hope this helps
Ciao
Sergio/Clarion of Skye 042/48
10 July 2009 - 18:48
Dear Milo,
Attached please find a picture of the tool.
Jyrki
11 July 2009 - 00:21
Hey Guys. Very helpful as always.
Lars, I cannot find the other forum sites, would you send me a hyperlink, please? I am sure they are there.
Sergio, you have given us the confidence to tackle this project.
Jyrki, we are now well aware of what we need to use and can order on-line.
Thank you all.
Milo
11 July 2009 - 18:16
Milo
Here the URL addresses of interest:
http://www.classicswan.org/forum/post_thread.php?thread=427
http://www.classicswan.org/forum/post_thread.php?thread=396
Suggest you take a look at the various contributions, there are over 6 pages of threads on various subjects
13 July 2009 - 12:55
below, in two separate posts, five pics of how you should do the job.
As per Lars Strom's instruction, it is suggested you flatten the seals a bit against the stock so the gland fits over them. Turn the gland at the same time, there are threads inside preventing the seals from sliding easily. If pressing the gland down onto the seals makes them swell out then do the opposite, lift up the gland and press in the seals one by one from below.
If the special tool Nautor provided with each boat when has been delivered is now missing, you can buy a USAG one which fits perfectly well.
Fair wind
13 July 2009 - 12:56
Ref. parts for UASG tool is:
282 TSN/50-80
20 July 2009 - 19:32
Dear Helpful Friends.... If you look at my original post and also the picture below, you will note the design of the Swan 47 does not allow for the same amount of wiggle room (or ability to lift) the gland. The quadrant sits almost  on top. Is it still possible to do this as you have described or is there something extra or special I need to know?
Cheers,
Milo
21 July 2009 - 18:25
Milo
You are right that the quadrant is too close to allow the gland to be lifted high enough.
There is a square portion on the rudder stock for the quadrant, check if it is long enough to allow the quadrant to be raised sufficiently after partly loosening its bolting around the stock. The upper rudder bearing is the next item restricting the distance the quadrant can move upwards.
If the quadrant can not be raised high enough it has to be removed from the stock.
Make sure the new packing stack stays on the round part of the stock below the square portion.
When putting the quadrant back it has to be aligned carefully with the grooves in the sheaves forward, and the steering wire tension checked.
The wires should be hand tight, tensioning them too much makes the steering stiff.
If the steering wheel has a King Spoke marked according to Rod Stephens recommendations, adjust the wires so the rudder is on the centerline when the King Spoke is straight up.
12 August 2009 - 18:37
Lars and company:
Well, we are up on the hard at the moment still trying to resolve our leak around the rudder post. This issue was not resolveable in the water.
Today we were hauled. After some issues, the quadrant was removed and an attempt to drop the rudder was performed. The workman state they need to remove the bottom section of the skeg to remove the rudder (see pic). The skeg bottom, made of bronze, had been thickly fiber glassed over. It also appears to be cemented on as well. There has been much effort to remove this section, so much so I am worried there may be a missing piece of vital information for removal. Their feeling was it is not wise to fiberglass this section.
What is the secret to the removal of the bottom section of the skeg?
Any comments or suggestions are appreciated.
Milo
12 August 2009 - 20:23
Milo
The bronze skeg shoe was not fiberglassed over originally. The recommendation for getting it off is to apply some judicious heating and hitting, but put a support under the rudder before attempting this, the rudder including shoe will fall to the ground when the shoe lets go.
Do not heat the shoe over 60 C  (140 F). When re-installing the shoe it has to fit tightly onto the GRP skeg, and new screws about two inches longer are required, so they can be tightened very hard from the threaded end with a big wrench, and the threads finally securely locked.
11 January 2010 - 20:54
We have the same problem.
We took the quadrant off and were able to lift the gland but the round section of the stock is not long enough and so the packing come on the square portion.  The yard recommends to cut a piece of the screw part to “gain” some round stock.
We are confused and do not know what to do.
Thanks for your help
Ludovic of RUMTRADER
Swan 47
12 January 2010 - 23:49
Ludovic:
We finally arrived at a solution after many days in the boatyard and the solution has been effective thus far. However, we cannot vouch for the long term fix.  Lars (the Professor) also gave us several other options which I will attempt to summarize, but we had time constraints such that we could not pursue them.
We also had a very short "round" bit of rudder post for the packing to be placed on, though perhaps a bit more than it looks like you have.  With the boat hauled out, it appeared as though rudder had settled down, effectively shortening the height of the post protruding up through the hull and rudder stock casing (the male threads of the gland). We attempted to have the skeg shoe removed in order to drop the rudder post, and allow replacement of the washer between the bottom of the rudder and the top of the skeg shoe. This proved a futile effort, and ultimately the boatyard fashioned a two-piece bronze washer (see pic of one half ) that they fit around the post, between the rudder and the skeg shoe (see pic), effectively elevating the rudder 1/4 inch (not much) thus giving 1/4" more "round" post for packing to go around.  The yard then placed packing and resealed the gland.  We didn't leak in the passage from Lagos, Portugal to Guernsey, Channel Islands, though we definitely have a suboptimal amount of packing in that gland.
There is a plastic washer at the skeg shoe protrusion that is what likely "wore away", and was replaced by the bronze washer the boatyard fitted, that may be replaceable if you can remove your skeg shoe. Despite great, even violent effort, the skeg shoe did not want to come off.
Lars also suggested:
That the ends of the packing band ring are cut with a long tapering overlap instead of straight off, due to the limited area for packing. Using a thinner packing and more turns may also work. If the gland bottoms on the outside locking ring before it compresses the seal, it would be advisable to put in a filler piece at the top of the gland recess.
An alternative way of fixing the problem is to shorten the rudder stock casing, i.e. the threaded tube coming through the hull, but this requires its removal.
Had we been able to remove the skeg shoe, and thus drop the rudder, Lars suggested that raising the rudder to allow ~10mm of stock above the rudder casing "This would be sufficient for an O-ring used as a seal around the shaft. The O-ring can not seal against the threads, requires a bushing inside them, with a flange above for compressing the O-ring a suitable amount. This needs to be worked out in detail if you choose this route. Alternatively a lip seal could be used."
"The other possibility is to raise the rudder approx 25 mm in order to use the existing packing band seal. This requires that the top of the blade is cut down this amount. Also the bottom of the skeg needs to be shortened so the bronze shoe can move 25 mm higher up"
We hope this is helpful.
Jill and Milo.
16 January 2010 - 10:29
Dear Milo,
Thank you for sharing your very useful experience.
We have checked if we could lift the rudder and gain some round section on the rudder stock.  As you see on the picture we could probably only gain a few mm and we need cm.   I cannot see what could have moved/changed since the boat was build.
During the last summer we took around 50 litres per day depending on the see and if we were with the engine or not.  The option of shortening the rudder trunk (chaumière) is discussed with the yard but this is a major change.  To do this we probably will have to take off the rudder.
I cannot understand how the original setting was, I am confident Nautor has thought of a solution but so far I do not have it.
Any suggestions?
 Ludovic of Rumtrader (S&S 47 hull 59)
16 January 2010 - 18:37
Dear Ludovic
Thank you for sending the reminder, otherwise your post would have gone unnoticed.
Milo's message mentions earlier suggestions, an additional one is to clamp a flexible neoprene gaitor around the casing, and around the rudder stock just below the quadrant to keep the water out. The gaitor has to allow 35 degrees of rudder angle each side. For example Lewmar show gaitors in their catalogue, also JP3 should have them.
In this connection I would like to ask where the upper end of the rudder stock is in relation to the upper end bearing sleeve? The sleeve sits in the fitting attached to the cockpit floor, and the position can be inspected if you open the emergency tiller screw cap in the cockpit.
Removing the upper bearing assembly probably allows the gaitor to be slid onto the rudder stock.
16 January 2010 - 22:09
Lars and Ludovic,
In the course of our repairs, we had the emergency tiller access open, the solution of a 'gaitor' certainly seems feasible given the set up  have if memory serves me correctly (i am unfortunately currently separated from my boat by an ocean!).
Milo and I will definitely keep this in mind if (when) we begin to leak again...
Jill
s/v The Last of the Normal People
16 January 2010 - 23:23
Lars,
Have gone to the Lewmar website, looking for gaitors/gaiters with no success. Can you give any more guidance, or better define who/what "JP3" is?
Jill
16 January 2010 - 23:30
Hey Guys:
Our emergency tiller screw cap was jammed solidly in place. We asked many people for suggestions on how to remove it. After attempting all manner of things, we finally gave up and had it cut away and a replacement one made (out of Teflon I think). It was an ordeal.
Milo
17 January 2010 - 20:13
Jill
The printed Lewmar catalogue 2006/7 shows gaitors on pages 215 and 216, but it appears the on-line selection today does not.
JP3 is the major steering system manufacturer in France, see jp3steering.com. They do not show gaitors on the website, but are likely to make them.
You can have your own gaitor made of neoprene rubber by the suppliers above, or at a rubber shop. For this you need the length and the circumference at each end. It must be flexible enough to allow the rudder to turn.
Two hose clamps also needed.
19 January 2010 - 18:13
PS
Would not consider the gaitor a permanent fix.
The rudder stock casing needs to be shortened or dropped to unhide more of the round stock. It looks like the casing could come out through the cockpit floor. Pls note that the casing has bearing bushings of plastic each end, they need new machined recesses if the casing is shortened. The upper bushing is end stop for the seal when it is compressed by tightening of the sleeve.
