Keel Bolts and General Topics on Keel - Stainless Steel trailing edge to keel
30 September 2009 - 10:22
Can anybody tell me how the S/S trailing edge to the keel is attached to my 411?
It has started to pit and I am not sure why, or if it needs replacing.
John
01 October 2009 - 09:17
Hi John,
I do not understand what you mean because I am not aware of any stainless steel trailing edge to the keel of my 411.
Can you please post pictures?
06 October 2009 - 20:49
07 October 2009 - 10:52
John,
I never noticed something like that in my 411 but I never had the chance to look for it and it may be hidden by layers of fiberglass or filler; I expect comments from other owners and from Lars Strom.
I wonder how s.s. and lead are fixed together and if the difference in thermal expansion is an issue (lead t.e. is quite higher).
07 October 2009 - 20:50
John and Daniel
The trailing edge consists of thin strips of stainless each side attached to the lead with short pieces of rod welded to their back side. The strips and rods are cast in.
There is also a thicker stainless docking shoe along the underside.
09 October 2009 - 10:40
Lars, last year when we had the copper coat put on I made the decision to remove the filler from the stainless as it was constantly falling off. Every year we would need to re work the trailing edge.
By exposing the S/S has this created a problem in terms of electrolosis? The S/S is antifouled.
09 October 2009 - 19:52
John
Normally stainless should not corrode, sounds like something in the antifouling, sea water, or an electrical leak could cause this.
In order to get epoxy paint and filler to stick to stainless the following trick is suggested: Sand the surface with wet and dry sandpaper using the epoxy as wetting agent, preventing air from reaching the surface during sanding.
28 November 2009 - 10:54
All, I recently meet with a marine surveyor who diagnosed Galvanic Crevice Corrosion.
  Galvanic series in seawater
Noble or cathodic end
   Stainless steel type 316 (2% molybdenum)
   Stainless steel type 304
   Stainless steel type 312 (0.4% molybdenum)
   Monel
   Gunmetal
   Phosphor bronze
   Admiralty brass
   Red brass
   Copper
   Naval brass
   Manganese bronze
   Muntz metal
   Lead
   Stainless steels with oxide destroyed
   Cast iron
   Mild steel
   Aluminium alloys
   Cadmium plating
   Galvanised steel
   Zinc
   Magnesium
Base or anodic end
Stainless steel appears in two positions in the table, which is confusing.  As delivered, and in normal use with the oxide film that forms naturally to protect the metal intact, stainless steel is among the most noble and corrosion resistant of materials.  However the maintenance of that oxide film requires the presence of oxygen which in certain places (such as under a barnacle) may be absent. In other areas as, for instance, where a shaft passes through a rubber bearing, the oxide film may be worn away and the oxygen prevented from reaching the surface.  Here what is known as crevice corrosion may occur, and where this happens stainless steel drops down the galvanic series towards the base end and is liable to corrosion.  The metal does not change; it is simply that its protective skin is destroyed.
It would appear that those of us with the SS apendages to our keels all have the problem. It is caused when stainless steel is starved of oxygen. When I cleaned up the filler around the keel when copper-coating last year, corrosion was evident. I then antifouled over the exposed SS which again started corrosive action. The knowledge of Stainless Steel working at the time of either design or build was clearly limited.
I am advised that I should clean up the stainless and just leave it bare as water has sufficent oxygen to stop any further action. I am looking at other solutions.
28 November 2009 - 16:15
John,
as a correction to my previous post and having hauled my boat, I can confirm that there is a stainless steel trailing edge also in 411-004.
Differently from what you found, the piece seems solidly attached to the lead and there is no sign of corrosion.
In any case, what Lars suggests is very wise and I will ask the shipyard to perform it.
I am sorry to dissent but I am pretty sure that in 1977 oxygen starvation and crevice corrosion in stainless steel was a known issue.
Daniel, 411-004
29 November 2009 - 19:46
John
Could I ask how you cleaned away the filler from the stainless? If wire brushing was used, the brushes are mostly of ordinary (=rusting) steel, and traces of this then remains on the surface. This will show up as rusting of the surface, although it is only superficial, and can be removed by light sanding.
Suggest that you check if this is the reason
01 December 2009 - 03:38
The crevice corrosion phenomenon has been well known for many years - the key thing to start it is the creation of the crevice itself (which has to be in a particular range of size for this to ideally occur, common examples of the worst geometries are like gaskets on flanges or washers on bolted assemblie, so if you picture putting filler or bondo on the SS and water getting under there you can see it would be just like that kind of worst case geometry, and trouble begins. Other things come into play and it can get complicated - but velocity is better than stagnant, so one option is to sail the hell out of her and never tie up, no worries - but if you have to dock sometimes, treatment might be in order. Epoxy paint, well applied, before any filler or bondo will help, then fill and final paint after. Something that has gotten better since the 70's are the materials and there are very nearly crevice corrosion immune grades of SS around, many made for the North Sea rigs and similar. Avesta 254 SMo is typical of an austenitic grade, there are others like Ferralium 255, a duplex grade, the list goes on. You can get this material in sheet, strip, plate, it is weldable, etc. So if you have to do any replacement of the corroding older SS, I would recommend materials like this, even though a little more costly up front.
Best wishes -
Geoff in WI, Corazon 411 #41
04 December 2009 - 19:41
Dear Geoff
You are right that the offshore industry has brought us more corrosion resistant and stronger stainless steels like the Duplex and Superaustenitic grades.
The pitting resistance for stainless can be defined with the Pitting Resistance Equivalent Number, for short PREN, which can be calculated with a simple formula based on the composition of the steel.
Here a list of PREN:s for some commonly used materials, the higher the better:
AISI 304                   20
AISI 316                   25
AISI 329                   31 (Duplex)
22-13-5                     39 (Rod rigging)
Avesta 254 SMo   48 (Superaustenitic)
For the older Swans with AISI 316 stainless material regular inspection is recommended for the following underwater items
- Docking shoe on underside of keel
- Keel trailing edge *
- Keel pocket covers *
- Lower ends of keel bolts *
- On centerboard models the pennant tube, pivot and stopper pins,
 centerboard *, centerboard casing *
- Propeller bracket
- Rudder skeg fairing pieces each side
- Rudder leading edge fairing piece
- Rudder stock and attached straps holding the blade
- Rudder skeg heel piece *
- Rudder stock casing
- Trim tab casing *
- Trim tab stock *
- Trim tab strap fitting *
- Trim tab lower pin assembly *
- Propeller shaft *
- Stern tube
- Through-hull fittings of stainless *
* refers to some models only
Routine inspection is particularly important for finding corrosion in time on critical parts long before it may become severe and finally cause leaking.
Such parts are the stern tube, through-hull fittings, CB pennant tube, rudder and trim tab casings
05 December 2009 - 19:38
Daniele / Lars / Geoff.
The filler had been falling off for a number of years, and I repeatedly kept putting more on. In an effort to reduce the amount of maintenance and cost each layup period I decided to clean up the fin completely. The yard carried out the work so I am not sure of the method they used.
Daniele, the fin is very securely attached to the keel, that is not the issue but the trailing edge is getting thin and spoiled. Unless you clean away your filler you will not see if you are suffering also. The surveyor said it was most likely that all yachts with this type of construction will have the problem.
Lars, I propose to clean up the remaining filler and antifouling by lightly shotblasting. The surveyor recomended leaving it bare afterwards as there is oxygen in salt water, but that way it will foul and if barnicles grow will continue to deterioate under the barnacles. It also look bad. So this is not an acceptable solution to me.
I am trying for a more perminant solution. Geoff offers two solutions, but is it possible to weld two types of stainless together? I am also looking at removing the stainless fin completely and replacing with carbon but still more research to do.
Lars, a few years back I took my keel off, the stainless bolts are so massive that this does not worry me.
06 December 2009 - 16:11
Two things - first, welding mixed grades - can it be done, yes, but - even if you weld same to same, the big problem is HAZ corrosion (heat affected zone has carbide precipitation, which makes that area preferentially corrode unless you solution treat after welding, which is impossible in this case) - so welding might not be a good idea, unless you could remove the part, weld/fabricate the new, heat treat, then reattach. As for the keel bots, size v corrosion - keep in mind that once crevice corrosion starts, it can be insidious and catastrophic, and can lead to failure even on bigger parts - which in the first place makes me a little worried to investigate my own bolts, but on the other hand, if there were a problem with potential corrosion failure of keel bolts in these boats, I would have to hope Nautors or someone would have the flag up by now. Does anyone have a detail sketch showing how the keel is bolted on? I know in my boat the heads are all glassed in from the inside of the bilge - in my boat, the previous owner did expose the bolts, retorque, and reglass, but that didn't involve exposure or inspection of the rest of the bolt.
Best Regards -
Geoff
06 December 2009 - 19:59
John
Suggest you try the wet sanding approach on the trailing edge, and fill, fair and paint as for the rest of the keel. What is the black stuff on the trailing edge in your picture? Leaving bare not recommended
You mention shotblasting, it should be noted that if done with steel shot this will cause rusting. Sand or grit blasting would be preferable.
The stainless trailing edge is not structural, and could well be removed if it continues to cause problems. To replace it with carbon fibre is not advisable, carbon must not be used underwater in contact with metals, electrochemically it is the same as graphite and will cause galvanic corrosion.
Can agree with Geoff that welding in situ is going to cause weld decay, (the common name for carbide precipitation). Generally it would be preferable to use grade 316L stainless for welding, this avoids the mentioned problem. L stands for low carbon.
Geoff
There is no history of corrosion on keel bolts. The critical area would be the short distance between the lead keel and the nuts, but there is plenty of mastic around the bolts here, keeping the water out. The lead and the galvanized washers also work as sacrificial anodes for the bolts if needed.
The bolts are cast into the keel, and can not be removed, or inspected except by NDT from the top. At the time of build the practice was to glass in the bolts. This glassing could well be removed, then the nuts need to be secured in some other way.
07 December 2009 - 03:34
Thanks for the reply particularly with respect to the bolts - I appreciate it.
Geoff in WI
ps on the welding , 100% right 316L is the way to go, for filler metal and base pieces (assuming you're not going even higher, like 254 SMo, etc), but in this case, I think the existing piece is probably just plain SS, not L grade, so even with L grade material for filler and/or second repair piece, the HAZ corrosion is still a risk as long as some of the original material is there.
I think it is important to note the point just made re: this is not a structural piece, so if it goes to hell, or if you take it out and re-do, we're not talking any major problems or failure, which is always nice to know so in the end you don't get too worried.
