Sail & Rigging - Swan41 mainsail ballslide system
15 November 2011 - 20:49
I have ordered non-laminate sails from North Sails for my Swan 41 (see my thread of October 24), so thanks to everyone who helped with this decision. I now have a dilemma about the ballslide system I hope to fit. It turns out that the Ronstan series 6 originally specified will require an additional track fixed to the original Nautor system. This has escalated the cost to 4250 GBP plus fitting. I am not sure I want to pay this premium for easing the handling of what is actually a relatively small main. Does anyone have any more cost effective recommendation for improvements on the standard plastic slide system?
16 November 2011 - 08:50
Robellis
Suggest you check if there is a Rutgerson car where the wheels would run on the aft surfaces of the track.
www.rutgerson.se
16 November 2011 - 10:53
Thanks Lars. I shall investigate and post my findings.
Rob
23 November 2011 - 23:54
Rob, I never found this an issue because the main is relatively small on the 41 and the deck is flat so its easy to get to. The only thing I did a few times a year was to spray the track and slides with some Harken lubricant and it was never a problem. Gavin
26 November 2011 - 18:49
Thanks Gavin. I think we are close to arriving at that conclusion too. We had hoped for some magical solution that would allow us to drop the main whilst running in a raising gale. But plastic slides will do.
13 December 2011 - 11:16
Rob, I went through the same process and to help with main sail handling got the sailmaker to increase the length of the battens. This has made a noticeable difference in terms of stowing.
John B
