Sail & Rigging - In Boom Furling Gear?! |
Posts: 462 |
After a research on the web I finally understood what Lars meant with the phrase "blocks in the sail at the reefing points...". I understood also that the way to do the job is to have captive two-ringed tapes sewn in all the sail reefing cringles and I realized that such a setup could be very handy in all cases, even with traditional reefing. I probably reinvented the wheel but I plan to ask my sailmaker to do it this winter. |
Posts: 162 |
Hi Daniel,
Posts: 154 |
Dear Philippe Dear Lars,
Dear Matteo |
Posts: 154 |
Dear Lars, thank you for your reply. Regarding point 1) I will contact the sailmaker for the installation of blocks. With regards to point 2)I hope to have understood correctly that you are referring to the winches close to the main entrance to the saloon (my original are Lewmar 48). This would mean anyway leaving the cockpit and getting to the bridge deck.In the alternative case of using the 55's in the cockpit, then the leads should go outside or inside the base of the 65 on the coamings of the bridge deck, and this seems to me complicate. At the end I think I will stay with the main halyard at the winch on the mast base. Thank you very much, Matteo (grampus 47) |
Dear Matteo |
Posts: 395 |
Dear All and especially the Professor, This is a very interesting discussion which I have been closely following. On my 43, I have the original boom which is not in great shape and so I am also considering a replacement boom. Currently, the traveler is located in the cockpit and I find that the mainsheet winch is awkward to use. If I understand the original logic, the placement of the traveler was a function of the "roller furler boom." Is it acceptable to move the traveler to a position before the dodger and place the mainsheet winch in a horizontal plane below the dodger? The Tartan 41, also a Sparkman and Stephens design, used this setup successfully. If so, I would think that the boom would need three bales, each with a turning block, to disperse the load. I am also looking to improve the reefing setup on my boat and I really like the idea the Professor recommended of adding turning blocks to the mainsail to reduce friction. Thank you all for a very informative thread. Chris Mabel's Casse Tete 43/003 |
Chris |
Posts: 395 |
Dear Professor, Thank you for your infomred reply. This winter, my plans include the deck removal and repair - either non-skid or teak - which leads me to painting and repairing the cockpit. So, with this in mind, I may change the location of the traveler as described. I would prefer to put this off for another year, and may do so, but that would mean repainting; etc. so, we will see. Thank you, again. BTW, I like Garhauer bocks; etc. Do you have an opinion? Chris |
Chris |
Posts: 395 |
Dear Professor, Thank you. Yes, before I were to make any changes to the current setup, I would contact you abou the calculations. Ironically, the rigger with whom I spoke today did not like Garhauer hardware! Do you have a preferred manufacturer of hardware? Have a great weekend. Chris |
Chris |
Posts: 395 |
Dear Lars, Harken is actually his preferred hardware provider. My experience with harken has been poor, but possibly I had the wrong style? And I did do some heavy sailing on my last boat. Having said that, All of my Schaefer gear held up to every condition while the Harken did not. The rigger says that he only recommends certain Harken equipment so that may be the difference between my experience and good experience. The fact that you recommend it carries a lot more weight with me than the rigger - the company he works for has a good reputation but I do not know him personally and have just entered discussions with him - as a result of this thread! Whichever route I choose, I would prefer to use one hardware company for all of the gear. This particular rigger also recommended Selden - certainly I know of their masts and booms but was unaware of their hardware business. Thank you. Chris
Chris |
Posts: 6 |
Dear Phillipe,
Posts: 199 |
Dear Phillipe, I also have a 47CB (68) and would very much like to install electric winches where currently I have Lewmar 55ST's. Did you my any chance take any photographs from below to show how you achieved this? Would it be easier to install 55 EST? I would very much appreciate being able to contact you. My email is: melboudrot@gmail.com. Mel, Cygnus Swan47CB (#68) Dear Mel
- Threads : 1709
- Members: 822
