S&S Swan Maintenance - gearbox reduction
24 June 2020 - 04:54
#22
Jan
You should also check the accuracy of your rpm counter.
24 June 2020 - 16:17
#23
Do you mean that the new alternator can give different rpm's?
And perhaps that I am not stupid?
25 June 2020 - 17:46
#24
Jan
Some rpm counters take their input from the alternator, and therefore the recommendation is to check the reading with a portable unit
07 July 2020 - 05:44
#25
Hi Jan and Lars,
My rev counter was not very precize. In the end used someting like this. Measurement at external flywheel and main shaft.
https://www.hbm-machines.com/producten/gereedschap-en-toebehoren/meetgereedschappen/hbm-digitale-toerenteller-met-laser?channable=e13762.TVBOODg4Nw&gclid=Cj0KCQjwl4v4BRDaARIsAFjATPkP75WxcaKYOhG3OvkFIzAhxg7r-vGwoEKgW1C4s3OCFtJ18b0p4_caApt9EALw_wcB
Good luck!
Jolling
14 July 2020 - 08:04
#26
Thanks Jolling!
jan
yulunga 38/110
