| S&S Swan General - Swan 57 Ketch Autopilot |
Posts: 15 |
Swan 57 Ketch Autopilot As owner of S&S Swan57 CB Ketch Lianda Hull #40, we noticed that when under sail at medium conditions of sea & wind from reaching to downwind, the autopilot is not coping, disconnecting very quickly. We wonder if this is normal & this system was made to work only in very light conditions, motoring. Is it possible to adjust or reinforce this original system? Thanks for your advise, Merry Christmas to you all Marc Busschots |
Hi Marc, |
Posts: 15 |
Hi Marc, Dear Daniel, Thanks for your quick reaction. We have on Lianda a Neco autopilot with B&G Hydra pilot control. We sailed her all summer using the autopilot without problem in the protected waters & light winds of new England.Just noticed that it will take some time like 30 sec to accept a new course; For instance if you motor on a course of 360° then you alter your course to let's say 90° , you'll have to wait for a minute or so prior to switch the autopilot on steering the new course, if not it will bring her back to her previous course, but once on the course the Pilot will hold the course very precisely. Sailing down the US coast towards Florida, we encountered more sea & wind, mainly beamreaching ( a joy!). But the autopilot will disconnect after 30 seconds,we hear cleary the sound of what we believe is the relay switch. We always trim the sails to have the lightest helm possible, the steering gear & autopilot motor are perfectly clean & dry & look in very good order.The helm is light;in fact the Autopilot is not coping with any sea more than a calm sea. do you need more infos ? Thanks for your time & help Marc Lianda 57/40 |
Marc, |
Marc and Daniel |
Posts: 15 |
Thanks for your help, professor, Merry christmas from Lianda, capt & crew Marc |
Lars, |
Daniel |
Dear Lars, |
Daniel |
Lars, |
Posts: 88 |
This is probably something you all are well aware of, but I had to learn it: To effectively steer the boat in all conditions the pilot has to have a fast response. Ten seconds hard over to hard over or a little less. This came from data obtained from the BOC where they sail single handed and the pilot is vital. On PLEIADES, a Buchan 37 that I built I ended up with a Wood Freeman pilot. We sailed her from Seattle to SF. We had NW winds about 20 knots most of the time. During the day we put up a 3/4 oz chute. The pilot steered all the way. A person would tire out very quickly. We found that a person could steer well for about 20 minutes, After that he would become sloppy. I sailed ATALANTA, a 74 ft. ketch down the coast. It had a Robertson pilot. It was powerful but way too slow. It would not handle the boat in other than very mild conditions, like maybe eight knots over the deck on a reach. Any pilot will handle the boat to weather; it's downwind where you need the fast response. On my present boat CYGNUS, S&S 40, 1971 I have a B&G Network pilot driving a home built hydraulic ram. Hard over is 8 sec. It has handled the boat in all conditions I have encountered so far in the twenty years I have owned her. The reason for building my own power unit was that the stock drive is not fast or powerful enough. To test for speed you punch in a 100 degree course change and time the wheel movement. |
Pete, Marc and Daniel |
Posts: 7 |
Pete, Marc, Daniel and Lars,
Dear Alberto |
Dear all, |
Dear Daniel |
Posts: 15 |
Dear Professor, Alberto, Daniele & Peter, Wish you all a lovely year 2012 & fair winds. Thanks again for your support. We tested the autopilot on flat sea, for Lianda to alter course of 100 ° it takes 35 sec. Thinking about Swanake hydraulic autopilot system, it is probably a more accurate & powerful device than the old Neco & B&G.I followed part of Swan Lake South American cruise, very interesting, we plan to follow the same way next year. Still, if possible, I would like to rely to the original system which proofs by time that it is a reliable one too, but, basicaly, if possible, let's try to keep things originaL.Also I am not so fond to play with the rudder system. If we do not succeed, then help of Alberto as how, where, by who.. the hydraulic system was installed will be most appreciated. Best wishes, Marc |
Posts: 16 |
Hi Marc & gang,
