S&S Swan Maintenance - Main sheet winch for a 411
08 January 2012 - 19:45
We will replace the main sheet winch on our 411, which appears to be the original one, with a self-tailing one. It appears that a Lewmar Ocean ST 30 can take the place of the current non self tailing 40. Is this the correct winch, or is a ST 40 required?
The current wedge is in bad shape, and I want to replace it. Any suggestion on what material to use, resp where to get this?
Christian IF 411/028
12 January 2012 - 21:11
Christian
Assume you have two or three parts on your main sheet. With two parts you double the power of the 30, i.e. it corresponds to a 60, with three parts to a 90.
Compare these with your primary winch size.
13 January 2012 - 18:01
PS
Do you mean the wedge under the winch? Suggested material is GRP, a shop doing GRP work can probably find a suitable piece which has to be shaped and painted.
14 January 2012 - 18:44
Thank you Lars!
Christian
