| S&S Swan Maintenance - Fitting non return valve to fuel tank breather |
Posts: 234 |
Fitting non return valve to fuel tank breather Hi, I am considering fitting a non return valve to the fuel tank breather. Some friends of mine this year racing from Newport to the Lizarad got flattened a number of times and it strikes me a sensible precaution to fit non return valve to stop any possible water getting into the fuel tanks. Any thoughts? John B |
Posts: 177 |
John, one thought: if you really want to install a non-return valve into a breather, you probably need to install it as close to the hull exit end as possible ... or the assumed knock-down that would cause water to flow into the tank will fill the breather line up to the valve. And you might want to make sure you can easily access and check the valve. Just imagine what happens when that one gets stuck. |
John |
