S&S Swan Maintenance - Draining of spinnaker rests/38
19 April 2007 - 11:28
The draining of the spinnaker rests tend to clog up on my boat. This leaves the poles semi-submerged, hence added risk of corrosion. I would be greatful if anyone out there has a good suggestion for how to solve this problem. (I have tried cleaning up with high-pressure water and air.)
Terje.
10 June 2007 - 19:12
I have the same problem,  but no solutions
11 June 2007 - 18:38
I have the same problem, too. I think there must have been formed some kind of air lock, since the spinnaker pole rests drain very well, but not before they are quite full of water, or the drain is initiated by pressure water.
Regards, Jyrki
