| Keel Bolts and General Topics on Keel - Keel problems on Outrageous S&S Swan 47/039 |
Posts: 36 |
Keel problems on Outrageous S&S Swan 47/039 A diary of dark discovery In order to be safe the surveyor recommended removal of the keel which one reputable boatyard associated with Swan scoffed at. Nonetheles I went with the recommendation of the surveyor - fortunately as, on further Investigation the stub of the hull above the keel joint had cracked along almost the whole length of the keel; on one side right through the glassfibre -where the long steel plate had, over time, worked against the hull as the mast pumped it! It seems the problem is one of long years of hard use rather than a particular incident. Part of the problem may be that these beautiful yachts can continue to carry large amounts of sail in high winds without complaint, something that has led us on more than one ocasion to push her pretty hard indeed! |
Posts: 53 |
I am sorry to learn of you problems - have you photographs of the damaged section so we can all learn?
Posts: 36 |
Photos will be uploaded in a week or two. Whole hull base currently being ground out before being relaid. Water ingress into the cracks has severely weakened whole of area under mast step which all has to be replaced. Ouch! |
Posts: 155 |
I bought my 47 Grampus #17 in 1995. I observed a crack in the aft area of the joint of the lead keel. I am pretty sure that there was a position of Nautor on this topic, as I saw in a letter of the shipyard in reply to the previous owner. The reason of the unconvenient looked to me rather strange: if I remember well it was stated that the crack was due to different coefficients of thermal expansion of lead and fiberglass and suggested to fill the gap with silicone.
Posts: 155 |
Oops, Grampus is hull # 16.... |
Posts: 36 |
Oops, Grampus is hull # 16.... The keel is now off and it is not a Pretty picture. Water ingress between the keel and hull, apparently over many years as well as the working of the whole hull stub area has led to severe delamination and weakening of the whole area. A sacrificial opaque glass fibre shell has been applied. All of the bad glass ground out and a new stub laid tapering up to the first stringer. The keel goes back on next week at which point all (except my bank balance) will be heading towards relaunch mid July. Pictures will be uploaded once received from the surveyor. |
Posts: 32 |
Dear Mark and dear Mateo, Rumtrader (47,059) also show these cracks between the keel and the hull. Following the recommendation of the different post on this forum I have just sealed the crack every year. They seem to appear more and more quickly during the season. Can you send me picture of the cracks and the way you solved the problem. Kind Regards, Ludovic |
Posts: 36 |
Dear Mark and dear Mateo, Rumtrader (47,059) also show these cracks between the keel and the hull. Following the recommendation of the different post on this forum I have just sealed the crack every year. They seem to appear more and more quickly during the season. Can you send me picture of the cracks and the way you solved the problem. Kind Regards, Ludovic Sorry to hear about rumtrader. Am still trying to get pictures from surveyor. If you have a problem of the same severity you will probably observe stringers detaching from hull above stub. Tapping along the hull above the stringers when rumtrader out of the water will show very easily whether the separation has occurred or not. Am happy to talk further if necessary. You can contact me on mark.stevenson@bluewin.ch or on + 41793415037
Posts: 155 |
I bought my 47 Grampus #17 in 1995. I observed a crack in the aft area of the joint of the lead keel. I am pretty sure that there was a position of Nautor on this topic, as I saw in a letter of the shipyard in reply to the previous owner. The reason of the unconvenient looked to me rather strange: if I remember well it was stated that the crack was due to different coefficients of thermal expansion of lead and fiberglass and suggested to fill the gap with silicone. I have a different opinion, not so easygoing as from Nautor but, too, not so dramatic. It would be good to know from the professor his opinion and, too, a search in the Nautor archives. It is important to see the pictures, too I noticed last summer in case of relatively rough sea that the bilge pump was working too often. ![]() ![]() |
Posts: 155 |
Dear Matteo
Posts: 155 |
Dear Matteo
Posts: 155 |
Dear Lars, |
