S&S Swan General - Swan 44 information request
01 June 2012 - 11:32
Hello,
I see that there is a Swan 44 for sale in Medemblik, I do not know the hull number (or boat name), but the boat was apparently built in 1973.  It does have a modified rudder / stern / skeg (Kaufman) and was re-rigged in 2008, including a new mast.  The mast however is sngle spreader, whcih appears to be very unusual to me.  The boat does look 'tired' and would require a considerable amount of work.
Are there particular areas that a surveyor should examine closely, associated with Swan 44's?
Are there particular problems that I should be aware of?
Any comments or advice would be most welcome.
Many thanks,
Trevor
03 June 2012 - 11:07
Dear Trevor
Suggest that you check the presentations of this yacht on a few more websites, you will find the hull number, the name, and that the mast is original.
For a yacht of this age the recommendation would be to look at everything
03 June 2012 - 22:34
Dear Trevor,
I've seen the boat in 2011, it's for sale for some time now. I'm not sure, but I believe it's imported from the USA. I can't give any comment on the condition of the boat, but I do know a very good surveyer in The Netherlands. So, if you are interested, sent me a message and I will give you the details of the surveyer.
Gerrit
10 June 2012 - 19:39
Hi, Trevor,
We have a 1973 Swan 44, hull #45 & she's a dream to sail. I agree that with the age of the vessel, EVERYTHING should be gone over thoroughly by a very picky surveyor. We also have the original Nautor mast, very substantial with single spreaders. Although the Nautor plate on the mast was missing, we did discover the 44/45 stamp on top of the mast we we pulled it for maintenance a few years ago. You might want to check the butt of the mast for corrosion during the survey if possible. We found that the last owner had pulled/painted the mast but neglected to provide for dielectric isolation between the steel mast step & the aluminum mast. We had to remove about an inch & have a G10 plug fabricated to keep the mast the same height.
Candy
12 June 2012 - 12:54
Trevor,
Suggest you contract a surveyor in your own country if different from where the yacht is. I have a long sorry tale related to this.  Drop me an email if you want details.
Hope it all goes well and you become the proud owner soon.
Adrian
03 August 2012 - 20:24
I own a Swan 44 ( currently in the Med): the original mast is single spreader. I don't know the boat to which you refer, but I would be interested in speaking with you if you are still looking for a Swan  44. Provide an email address and we can discuss.
Thanks.
Bill
