| S&S Swan Maintenance - Seacocks "pinked out" on a Swan 47 |
Posts: 36 |
Please see thread in this section dated 29 September 2009 |
Posts: 36 |
Thanks! |
Dear all |
Posts: 396 |
Dear Professor, I replaced all of my seacocks; although I did not notice any "pinking," the bronze through bolts had weakened to the point that very little torque snapped each one. The seacocks themselves, although old and seized, did not look too bad. Chris Mabel's Casse Tete 43/003 |
Dear Chris |
Posts: 396 |
Dear Professor, Yet another surprise with my boat! The seacocks were definitely glassed in AND through-bolted. This must have happened after the boat was seized and refurbished. As you already know, there are a lot of changes that are not in keeping with the original nor with good practice. Time will cure all these! Chris |
Posts: 119 |
Dear Lars:
Posts: 43 |
Pinking is due to galvanic corrosion between the copper and tin of the bronze alloy. The tin disappears leaving the copper behind seriously weakening the fitting over time. After 30 years it is undoubtedly high time to replace the through hulls. Bonding the through-hull together electrically and attaching the bonded set to an extrnal sacrificial anode will slow or stop the reaction, but will not undo the damage done. I replaced all the Blakes throughhulls first thing after purchasing my 41. John |
