| S&S Swan General - Swan 38 deck mould |
Posts: 19 |
Posts: 252 |
There are Swan 38 with teak deck or fiberglass deck. Is it possible to simply add the teak on the deck in fiberglass or both types of deck are too different and from different casts? thank you If you are looking at a 38 with a fiberglass deck and want to know if you can put a teak deck on her, generally the answer should be yes. She may have been made with a teak deck, the Professor may know, but as long as the deck is sound, and you're dealing with a deck maker who knows their business, the issues relate mostly to fit up at the toe rails (you want a thinner deck there, so as not to create a deep gulley), your hatches and other thru fittings, skylights and prisms, etc., and all sailing hardware (shroud fittings, mast base pulleys, genoa tracks, other anchor points, etc. must all be reset and rebedded on the new deck. I have seen these boats getting decks made board by board from teak, or, like mine, made from CNC cut sections by a big deck maker (Teak Decking Systems www.teakdecking.com). Figure on spending some serious money either way. |
Posts: 252 |
Also, go to the 'documents' page from within the model page for the 38, on classicswan.org, and read the article that is there - it talks about the teak decks and some of the issues involved. |
Posts: 19 |
Thank you for all these explanations.
Dear Cocatrix |
Posts: 19 |
Dear Cocatrix thank you professor
