| S&S Swan Maintenance - New toerails for Swan 41/031 |
Posts: 83 |
New toerails for Swan 41/031 As a result of a collision in the Para river with a 300ft barge, I am about to embark on a job which I never thought that I would ever do, that is to replace both toerails on my 41 "Trinket". My insurance only covers the replacement of the port toerail, which was bent beyond any hope of repair, however I have decided that it is essential to replace the starboard as well at my own expense. The new toerail is made in 3 sections with 2 joiners, so if only the port was replaced, the boat would be asymetrical, as well as having the unacceptable contrast between one 35 year old toerail and one new. I have just placed an order with Nautor for about 12000 euro, and have booked a sympathetic boat yard with a suitable shed. We hope to do the job in 2 months. I will be doing a lot of work myself, with the unattractive prospect of undoing around 450 bolts. The proprietor of the shed has done quite a few toerails in the past, however never on a Swan, usually on Bavarias where apparently they fall off every few years. Can any owners give any recommendations or advice as to the progression of this work, such as best technique for bolt removal, best bonding compounds, suggested torque to do up the new bolts, etc, etc. Any advice would be gratefully received Cosmo Little
Posts: 252 |
Cosmo: |
Posts: 73 |
HI Cosmo, I just replaced the Toerails on my 48' but I decided to go for teak ones instead of the original aluminium ones. You need a lot of patience, a friend to help you tightening the bolts from inside , four sicaflex tubes and and impact screwdriver ( better if air pressure driven). If you need any advice feel free to contact me at Sergio dot Revello at gmail dot com.
