| S&S Swan Maintenance - Swan 41 door catch |
Posts: 38 |
Swan 41 door catch ![]() ![]() |
Posts: 166 |
Hi Andrew, I renovated our three doors last winter and also remarked this. I think the complete mechanism can be removed via the front side, but is it covered with veneer that was added after the lock had been inserted. Christian IF 411/028 |
Dear Andrew and Christian
Posts: 38 |
Dear Professor and Christian, thank you for your advice. I have made a puller and put quite a lot of pressure on it, far more than I imagine rust could exert on timber, and no sign of movement at all. Did I understand correctly that the only screws retaining the latch are the 2 that also secure the knob and pass through the latch? It seems rather un-Swan like to veneer over either the means of removal or other securing screws. Thanks and best regards, Andrew |
Dear Andrew |
Posts: 177 |
I had the same problem -- here is how the lock came out. The lock, partly pulled out of the door ![]() Clamp construction Here is what it looks like |
