| S&S Swan Maintenance - Fuel Line and Tank |
Posts: 396 |
Fuel Line and Tank Dear All, I had the enjoyable experience of pumping approximately 18 gallons of diesel fuel from the tank yesterday and then cleaning the tank. I have two questions: there is a nipple at the bottom of the tank which is accessable near the drive shaft which had a clear water hose attached to it; what should this be; e.g., is it a valve? And, from the picture you will see that the fuel hose at the top of the tank needs replacement; is there a reason for it to be curved or can I run a straight hose to the tank? Chris Mabel's Casse Tete Dirty Tank Clean tank Fuel Hose |
Posts: 234 |
Chris, not definate but the nipple could be used for draining off any accumulated sludge in the tanks. Many of my friends with more modern yachts have this arrangment and its a god send if you go cruising to be able to clear out the sludge every so often. John B Swan 411 010 |
Posts: 396 |
Hi John, Yes, I believe that is the purpose. I was wondering if others had one and if the nipple had a valve. It's unclear from what I can see. Obviously a valve would be helpful. The previous owner attached a clear hose to the nipple and then raised it above the top of the tank, held in place by a bracket. Not ideal. Thanks, Chris |
Posts: 119 |
Hi Chris:
Posts: 396 |
Dear Hiro, Thank you for your reply. I will examine the current fitting carefully. It currently has a nipple attached to a fitting, which is not completely visible. It's hard to understand that someone would go to the effort to place the nipple but not install a valve. I am wondering if the valve is there without the handle - I will check and get back to you.
CHris |
Posts: 30 |
Hi, On my boat I also have a take-off at the bottom of the tank, which as John B. mentioned, is a real bonus for cruisers. 24 hours after I fill my tank (I give time for water etc. to go to the bottom), I drain off a pint and throw it away too. If the boat has been standing for a long period I will drain off a pint to get rid of water from condensation.
The clear hose running up the tank that Chris mentioned is probably marked and was used as a fuel gauge. (I would suggest only turn on the valve when you want to know the level of fuel, don't leave it open all the time.) Happy sailing David 43/12 |
Dear David, |
Posts: 396 |
Dear Members,
Posts: 119 |
Chris:
Fuel Fill Hose in Background |
Posts: 396 |
Dear Hiro,
Posts: 148 |
HI Hiro,
Posts: 119 |
Hi Rob:
Posts: 148 |
Hi Hiro,
Posts: 148 |
Hi Hiro,
Posts: 203 |
Hello ROB.
Posts: 203 |
Hello ROB.
