| S&S Swan General - Swan 47CB centerboard issues |
Posts: 3 |
Posts: 126 |
John, I own the 47CB "Black Tie" and had similar questions to yours prior to buying 4 years ago. I got no answers from the US Swan forum but was encouraged by one example that had won her class in the Bermuda race.
Posts: 3 |
Great, thankyou Gavin, that answers the main points of my query. Roughly how long does it take to fully lower and raise? (I had a frustrating experience on an Etap that required about 20 minutes of winching each way).
John I can not quite agree with Gavin on two points: - The rig is not shorter but same length as other 47:s if original. - The weight of the board is 209 kg, or 461 lbs. There is also a version around denoted NYYC 48, basically it is a 47 CB with 2 ft longer boom and 1.2 ft longer spi pole. The pennant has two parts and passes around a sheave in the board, the dead end is found under a small screw cap at the saloon table where the bigger tube terminates, the other part goes up to the winch on deck. With this arrangement the pennant can be hauled around and inspected over the whole length by attaching a piece of line to the end. The sheave in the board comes out just below the bottom of the lead when the board is in down position, enabling a new pennant to be reeved by diving. Later S&S models with CB may have an electric or hydraulic lifting system controlled from the cockpit, but the pennant arrangement is basically the same two-part system. There may also be sideways adjustment for the board in the slot with threaded plugs through the lead. this prevents the board from making a noise when the yacht rolls. In conclusion the CB system is rather sophisticated compared to many other yachts. Kind regards Lars
Posts: 126 |
Sorry for the slow response. It takes about 2 minutes to raise or lower the board which is done with a lanyard running to a Luke winch about a metre aft of the mast on the deck. The winch is interesting in that it allows you to position the board as any point and it holds that position. Its a good system and doesn't need any power assitance. To answer the the "professor's" point. All 47CB's are NYYC 48's and the spec is in the S&S database. This means accomdations 2 ft back from the original so smaller aft cabin, bigger tanks, more ballast, shorter mast and longer boom. Arthur Beiser, author of the Proper Yacht was one of the first customers and describes the boat in detail in that book. Later versions of the Swan 47 fixed keel also had the NYYC accomodation and the called them 47 Mk 11's. Regards, Gavin
