| S&S Swan General - Position of the multifunction display in the cockpit |
Posts: 26 |
Posts: 155 |
Hi, I think it might help much if you can send a picture of the arch on top of your wheel pedestal. My opinion is that the best and easiest solution would be a bracket mounted in such a way that you can swivel the instrument right and left, up and down, so that you have always the best visibility, sitting or standing, at port or starboard. In case, I will show you my bracket in s/s, made to measure and very unexpensive, regards, |
Posts: 75 |
Hi, here's my solution at CAID (431-12). The MFD's 12" latest B&G.
Posts: 199 |
Hello GG...
Cockpit view General view |
Posts: 3 |
Hello IHe,
Posts: 75 |
Hello Henri,
Posts: 252 |
I had a new fwd steering bearing holder machined out of aluminum - the change was to extend a rectangular tab vertically upward a couple of inches, with 4 tapped holes, to allow mounting of a Navslide quick mount. This provides perfect look at the helm, then the display can be rotated )and locked down) for viewing from either cockpit seat...it's sweet - compact, no big new parts. Display is Furuno MFD8....you can see it all in this shot, if you zoom in - ![]() |
Posts: 56 |
Dear friends,
Posts: 234 |
Have you considered having your main screen down below and having a tablet on deck linked through wifi. Much cheaper!
Dear John,
Posts: 26 |
After thinking a bit ' of time for a solution , I started work rate , what is not definitive , but I can still assess changes . I think it will lower the vertical frame of a few centimeters . To post a picture of what I'm doing . We accept suggestions .
Posts: 26 |
I put two more photos |
Posts: 68 |
Hi ggaliza.
Posts: 16 |
A few pictures of how I have solved it |
