| Sail & Rigging - Swan 38 - Mast height & effect |
Posts: 5 |
Don It is true that the 9 first yachts had the short One Ton rig, but also some higher hull numbers have this rig, there are altogether 32 of them out of 116 built. It is possible to compensate for this in light weather by using more overlap on the headsail and longer spi poles, although the length of the latter is restricted by the deck recess. In stronger winds the short rig has an advantage, however. I would say that the influence on the pitching is unnoticeable, unless someone has clear evidence to the contrary. Kind regards Lars |
