| S&S Swan Maintenance - Convex circles on our rudder 1987 53 |
Posts: 2 |
Dear Eric, |
Dear Eric There is no reason to be concerned, what you see is part of the original rudder blade concept. There are conical circular recesses in the blade, and the skin laminate continues also in the recesses. At the bottom of the recesses are flat areas bearing against the stainless flag welded to the aft edge of the stock, with through bolts holding skins and flag together. There are thin covers over the recesses. A steering system drawing is available from Nautor, or you may prefer to order a complete Owner's Manual with text part and arrangement and system drawings. Contact technical-service@nautors-swan.com It would be good to check occasionally whether there is water in the rudder blade, this can be done by drilling a tiny hole at the lowest point. The hole can be sealed with a screw+ mastic, or with epoxy. This check would also give a warning if the stock corrodes inside - there would be lots of rust coming out Kind regards Lars |
Posts: 2 |
Hi, Thanks all for the support and the warm welcome. Lars where would you suggest drilling the hole to check for drainage? How far up from the bottom and how deep? Do you reccomend a hole on each side? How large an area do I need to fair the epoxy plug to get good confidence that the plug of epoxy will seal the hole to prevent further ingress of water? Regards Eric |
Dear Eric Suggest you drill a tiny vertical hole on the centerline at the lowest point of the blade, and seal it with a few drops of epoxy. If there is water in the blade the leading and trailing edges should be checked for damage. The blade consists of two halves joined along the centerline. Also the joint where the stock enters the blade should be checked for leaks. Kind regards Lars
