S&S Swan General - Swan 38 - DRAFT
30 January 2017 - 22:27
Swan 38 - DRAFT
Can someone help with an anomoly?
The builders certificate shows the draft at 6.04ft which is 1.84 metres
The Certificate of British Registry shows that the draft is 1.73 metres which 5.7 feet
Which is correct?
Many Thanks
Tom Barth
Pandra
Swan 38 111/116
31 January 2017 - 09:22
Tom
Pls note that this is a register dimension, and the certificates use the notation "depth", which is the internal height, either to the deck edge, or to the imaginary deck camber midships. The coachroof is ignored.
Register dimensions vary in different countries because the definitions can be different, as written down in national laws. Also, the legislation is made for ships, and may not always be suitable for sailing yachts.
31 January 2017 - 18:49
Very many thanks for your prompt reply - as always
Tom
