S&S Swan Maintenance - Borg Warner gear
22 April 2017 - 10:59
Borg Warner gear
Would anyone know identification detail on original Borg Warner Velvet Hurth gearbox,  connected to Perkins 4.108. (1978) Its for checking oil specification and also oil level on dipstick.
Thorbjorn/Ravn 411-036
22 April 2017 - 17:56
Thorbjörn
Assume you mean the type notation, it is Velvet Drive AS15-71CR.
There should be a manufacturer plate.
27 April 2017 - 09:43
Thornbjorn,
I have both the Service and Owner's manuals of the BW Velvet Drive transmission and if you want I can send them to you.  I think that they are also in the manual section of this site and I will check with Matteo.
29 April 2017 - 01:27
There is a pipe plug with a square head on the port side about in the middle . It has a dip stick attached. Use automatic transmission  fluid
