Sail & Rigging - Swan 40 whisker pole
26 June 2017 - 18:43
Hi all
would anyone happen to have the details of the whisker pole originally fitted to a swan 40?
Im looking to purchase or make one any help would be much appreciated
many thanks
Neil
27 June 2017 - 10:17
Dear Neil
The 40 did not come with a whisker pole, but if you mean a spinnaker pole the tube dimensions were 100 mm diameter and 3 mm wall thickness.
Could 40 owners pls confirm.
02 July 2017 - 05:20
Hi Lars and Neil
I just checked mine and Lars is correct on the sizes.  I am considering as a winter project building two Carbon fiber spinnaker poles... a little easier on the foredeck!! Having a code 0 and a Gennaker both on a top down furler  I am questioning this but one needs projects...
I do not have a whisker pole. I have seen a lot of Swan 40s and have never seen one with a whisker pole.
Good luck finding one be it a spinnaker pole or a whisker pole.
Mike from Stormsvale
02 July 2017 - 14:10
Take my hat off if you build the carbon poles yourself :-)
If you need advice I would be glad to contribute. About half the weight is saved.
03 July 2017 - 19:38
Hi all
thanks for the responses I think it makes a little more sense now.
i have an adjustable whisker pole and it's the spinnaker pole that's missing.
cheers Neil
09 July 2017 - 06:34
Thanks Lars!!
 I am looking forward to the project and will be back to you with questions.
Hope all  is well with you!!!
All the best
30 September 2017 - 04:42
I have a reaching strut that came with the boat. It stores on deck on the starboard side in factory made chocks. Is that what you mean?
