| S&S Swan Maintenance - Maxprop pitch calculation |
Posts: 13 |
Maxprop pitch calculation I'm trying to figure out the right pitch for following setup on Swan 41: Engine Craftsman CM4.42 Power 30,9 kW / 42 hp Max. Engine Speed 3.000 rpm
Gearbox TCM60 ratio 2.65
Prop: Maxprop Easy, Four blade, 17inch
Dear V-V Your setup requires a fairly big pitch, more than the 24 degrees given in the Easy manual. Would like to ask if you can give the actual propeller diameter measured to the nearest millimeter?
Posts: 13 |
Hi Professor |
Dear V-V With reduction ratio 2.0 the recommended pitch angle is 18 degrees.
Let me know how it works out. Full throttle rpm and speed would be of interest.
Posts: 13 |
Thank you Professor!
This really helps extesively.
I'll let know how things work out.
Kind regards |
