S&S Swan General - Stern light manufacturer / supplier
10 June 2019 - 14:07
Does anyone know the manufacturer of the original stern lights as used on the swan 38 and probably others? They slide down over a little bracket welded to the pushpit.
10 June 2019 - 17:56
Hi Pete,
Hella Marine
11 June 2019 - 05:27
Just in case the Hella Marine lights are not available anymore: there is a similar-looking system by Peters & Bey. I am not sure if the same mounting can be used but it looks like it could work. Check one of the suppliers: I add a link below; there is a category "accessories" that lists the mounting as well, and most of the individual parts like the lens can be obtained separately:
www.toplicht.de/en/shop/lampe-leuchte-und-laterne/positionslampen-und-navigationslichter/peters-und-bey/navigationslichter-pb-410-aus-edelstahl
Martin
11 June 2019 - 06:19
Pete,
On Infant (38/014), the navigation lamps are made by Aqua Signal (Series 50).
Jyrki
07 July 2019 - 19:15
Brilliant, thanks for your kind help everyone, will investigate...
