| S&S Swan Maintenance - Cutlass bearing stuck! |
Posts: 117 |
Cutlass bearing stuck! Dear Friends, I am in the process of removing the cutlass bearing in the p-bracket, with the shaft in place. It seems there is a bearing used with a brass housing that corroded with the stainless steel p-bracket. I have had a cutlass bearing remval tool made but it won't get loose. I am trying to avoid lifting the engine for removal of the shaft. Kind regards, Jan 38/110 yulunga |
Dear Jan, |
Posts: 117 |
Dear Matteo, That is very good news! kind regards, jan |
Dear Jan, |
Posts: 117 |
Good idea! (Hope I don't forget it, while I am busy doing it......) |
Posts: 117 |
Dear Friends, Unfortunately it didn't work. The shaft is too long: it reached the skeg before the other end was out of the boat. I think Matteo's engine is longer and his shaft is shorter. We succeeded however in removing the bearing by sawing and cutting it! Quite a job. But very happy now. kind regards, |
