| S&S Swan General - What are they for? ...Lars? |
What are they for? ...Lars? ![]() |
Dear Daniele,
Posts: 243 |
I agree, I use the fitting aft for my spinnaker or Asym sheets on my 40. This is more or less a standard approach. I think the eye on the end of the boom is for a preventer. i.e to stop the boom from flying across during an accidental jib. Have seen the results of not using one (not on my boat). Broken booms cracked heads.... Lars will know better but as it looks like you have a boom jeefing system (i.e. roll the main onto the boom, this would probably be the only place to put a preventer.
Posts: 243 |
Looking again at the picture, you have a hard vang. So reefing is probably slab not roller as I first suspected. Was this vang original? Also your main sheets?? seem different. Another option is that the eye is for end boom sheeting?? Anyway, to me it is not clear what is original on your boom. The eye is and I have seen people use this as an attachment point for the main sheet. We need enlightenment from the professor!! or others with a similar setup.
I am sorry but I am not totally convinced yet.
Sorry, I forgot the picture!
Posts: 243 |
Hi Daniel,
Mike, |
Dear friends The lugs at the aft end of the toerails are for the attachment of the spreacher blocks (spinnaker&reacher). These blocks originally came from Palmer Johnson in the US, the only supplier of big blocks at the time. The blocks had two sheaves in tandem, you can see similar ones in the Harken catalogue, but they are called spriddle. The hole in the boom endplate SB is for the topping lift. The dead end was attached to the eye on top of the boom end, and the line led up through a small block on the lower end of the lift, down into the mentioned hole, and forward to the cleat on the side of the boom. It is advisable to use very flexible line both for the tail and the lift in order to avoid frequent adjustment. Originally the lift was wire, but should better be replaced by line to reduce chafe on the sail. Today only boats without hard vangs use topping lifts Kind regards Lars |
Posts: 43 |
Gentlemen; On my 41 /018 I have a jack-screw main foot tensioner which is visible in the attached photo. The hole into which it fits is offset from the centre of the end-plate. I have rerigged my jib sheet attachment to the much stronger eyes at the bottom of the boom-end ring via 2 shackles and a "D" ring, again as can be seen in the picture. I believe that before the hard vang was installed the original topping lift would have attached to the single eye opposite the current sheet attachment. John ![]() |
John Nice picture! For the people not familiar with the mainsail foot outhaul for roller reefing booms - the adjustment is done by inserting a winch handle in the socket and cranking away. Inside the boom is a long screw and the outhaul lug moves along it. The boom end fitting center bail is strong enough for the mainsheet. It appears you use a spreacher block for the mainsheet tackle, which brand is this block? It is correct that the eye on the upper edge of the boom end fitting is for a topping lift. Lars |
Posts: 43 |
Professor; I have been replacing all of the running rigging blocks with modern Lewmar polycarbonate blocks. The end plate on my boat appears to differ from those under discussion. The picture is a freeze-frame from an avi video I took while in the Straits of Georgia off the British Columbia coast last September. The wind was about 35 knots, she was double reefed and going like a bat out of hell! John |
