| S&S Swan Maintenance - 411 work questions for the professor |
Posts: 41 |
Pippo Thank you for your message 1) Leaking diesel would produce a strong smell, and "thick gunk" indicates that some other stuff may be involved. Suggest you flush the bilges thoroughly with fresh water, starting from the ends, and also flush from the topsides down where possible. There should be a limber hole chain in the bilge running from bow to stern, by pulling on the chain blocked limber holes can be opened 2) Deck fitting bolts are either threaded into aluminium back-up plates, or have nuts. Remove the overhead panels to see their lower ends. If the threads in some back-up plates are gone put nuts on the bolts 3) The windows are held by the frames on the outside. The frames are not metal but GRP, and should be removed with care in order not to break them. It is very important that there is a wide enough groove for sealant around the perimeter of the window acrylic, at least 5 mm recommended, and a groove depth equal to acrylic thickness. Further put sealant under the frame when reassembling. 4) The life raft locker was sized for the commonly used raft in the 1970:s, the brand was Beaufort if I remember correctly. The locker dimensions are believed to be 770 x 350 x 370 mm, but suggest you check this. The verified dimensions are needed for finding a suitable raft. 5) Many 4.108:s are still working fine, and if the engine starts easily and otherwise is healthy it could still serve well. A little more information is required referring to the reported lack of power: What is the high idling rpm (full throttle in neutral), and the full throttle speed and rpm in forward gear? Is there black smoke at full throttle, or also at lower rpms? Are the propeller dimensions known? Kind regards Lars |
