| S&S Swan Maintenance - Teak Deck Cleats and Grab Handles |
Posts: 38 |
Teak Deck Cleats and Grab Handles Dear Forum, I need to replace the 12 x teak deck cleats and 4 x teak deck grab handles on Scotch Bonnet. The dimensions are cleats: 280mm length with 80mm between bolt centres; and grab handles: 390mm/400mm length with 280mm between bolt centres. I don't know if these dimensions are peculiar to the 41 or are common with other models. A few questions... can anyone recommend a supplier for these parts? If replacements are obtained in teak should they be oiled or varnished, or left natural as with the deck? Has anyone/is it considered reasonable to consider replacing with stainless, and are any suppliers recommended? Thanks from Sydney, Andrew Scotch Bonnet 41/039 |
Dear Andrew, |
Posts: 38 |
Thanks for your advice Matteo. It took a little while to arrange but very happy with the result and now to fit them! Have also had a few spares made, as suggested. Fair winds, Andrew Scotch Bonnet 41/039 ![]() |
Posts: 48 |
Where did you get them made? |
