S&S Swan Maintenance - Gelcoat color code of swan 38
17 August 2008 - 21:51
Does anyone know the (jotun ?) color code of the cockpit of the swan 38 ?
Kind regards,
Jan Kooistra
Yulunga
Swan 38/110
18 August 2008 - 12:11
Dear Jan,
I am not sure Nautor used to get Jotun back in the Seventies, I know now they use Jotun NG 2000, which is bright white and not as "beige" as it used to be in the past
Fair Wind
18 August 2008 - 19:14
Dear Jan
The same colour was used for the entire deck including cockpit, and I would guess Jotun 200 was used, is today denoted 2000.
18 August 2008 - 20:41
Thank you very much.
Kind regards,
Jan
03 October 2013 - 08:59
HI! I just got these color codes from a Finnish specialist company called Terpol Oy when buying some gelcoat etc for CAID:
White gelcoat/topcoat: Rheichhold 2000
Brown topcoat in the bilges: Rheichhold 4005
They showed me the original gelcoat Nautor used and this Rheichhold 2000 cured side to side and I did not notice any difference between them in the bright sunlight. I also got the next codes for the white gelcoat, but I have not a glue what do they mean or where to use them. But just for the information if You happen to stumble into to them:
White gelcoat: NCS0401Y32R
White gelcoat: X48W
IHe / CAID
